Question about Canon Office Equipment & Supplies
My Cannon 150 printer is smearing the print when I print anthing
    Sergeant:
  • 162 Answers
Go to your print utility and use the clean head option in the utility.
Posted on Mar 20, 2011
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Toner smears on all print outs. Looking for what part to replace.
Do you mean when the print comes out the toner smears on the paper when you touch it? If so, then it's the fuser that isn't working properly.
However, if you mean when the print comes out there is smeared toner in various places on your print, but the smears are fixed to the paper, then the cause is more complicated and could be caused by a number of different problems within the printer.
Mar 03, 2014 | Xerox FaxCentre F12 Laser Printer
Cannon MG6120 printer will not print text. I have cleaned print heads several times. I think I have a clogged print head. Which of the 2 black ink cartridges prints text? How do I clean a clogged print...
I think you need to do is reinstall you software driver for the print program and start with known parameters. Then you can try to clean the heads. You should get something out of the printer if the heads are plugged it might be a dot or smear on the paper.
Dec 31, 2012 | Canon Pixma MG6120 InkJet Printer
I believe my ink dried out in the holder bracket. I cleaned it with alcohol and replaced the -color and black ink cartridges with new, and can only get a littles ink smeared across the page on the first...
If ink dried out it's done. Recycle it and get new cartridge. If cartridge is more than 50 dollars don't buy it. Go to Walmart and you can by a brand new cannon printer with ink cartridge for $49.00
Jan 11, 2011 | Computers & Internet
What is the cartridge number of HP 4335 all in One Printer
the part number is hp 21 black injet print cartridge part# c9351aa, hp 22 tri-color inkjet print cartridge part# c9352aa cartridge for everyday printing and the high volume printing cartridges hp 27 black inkjet print cartridge part# c8727aahp 22xl tri color inkjet printer cartridge part# c9352ca; these cartridges is for hp officejet 4355 all-in-one inkjet printer
Nov 21, 2009 | HP Officejet 4355 All-In-One InkJet...
Cannon Pixma MP830 - smearing on front when printing
If you have taken it apart that far then you are way ahead of the game. My suggestion would be to clean the head or anything the ink touches in a vinegar/water solution. The vinegar dissolves any dried ink whereas the soap may actually gum things up. If that doesn't work or improve things I would say that your print head has a seal problem. The replacement print heads are worth more than a new printer so you can probably figure out whats cheaper to do.
Aug 21, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My computer isn't printing the way it should. It is a CANNON 1800
Hello michelle9mit,
First of all you will need to clean the surfaces of the DRUM, and paper feed path and assembly. This might be the cause of most of your problems. I would suggest also making sure the paper feed sensors are cleaned and tested for the proper voltage levels. As far as the slanting paper the paper feed mechanism may have to be cleaned and aligned. I would also make the suggestion that if you do not have a mechanical background you should get a professional service center to do the work for you, but first get an estimate on the cost and if it is too much, you may want to consider getting a new printer and getting a maintenance plan for it.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 14, 2009 | Dell 3100cn Laser Printer
I am having problems when printing out a copy from my computer.
if run your figure across the print, does the print smear?
if os, yu need a new heater element, if no check the roller for dirt and print smear.
Jan 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Ink smears ,
You need to clean the print head until the smears clear up
Dec 15, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Vista software not capatible with cannon MP 150 pixma
This is the page where the driver file is located, click on I Agree Begin Download
Easy Print Software download page location.click on I Agree Begin Download
MP Navigator download page.click on I Agree Begin Download
This should just about cover all the software
Regards,
Worldvet
Please don't forget to rate all our solutions on FixYa
Jul 02, 2008 | Cannon Office Equipment & Supplies
21 people viewed this question
old marine
old marine
