Question about Baby Einstein Around The World Discovery Center
How to remove the seat cover on the exersaucer for washing
I washed the seat cover of the exersaucer and cannot get it back on
It has likely shrunk. Try wetting it and then stretching it on while it is wet. Let it dry while it is on.
Jan 03, 2011 | Evenflo ExerSaucer SmartSteps Active...
How to put the cloth seat back on
http://www.evenflo.com/resource.aspx?id=467&rcid=19
This may not be the one you have but this site will advise you how to get model and manufacture date so that you can get exact instuctions.
Jul 05, 2010 | Evenflo Exersaucer Triple Fun Active...
Reattach seat to Evenflo Exersaucer
Match the red arrow on the fabric seat to the middle of the seat back. Use a crochet hook to fish the elastic straps through the slots. Pull the elastic straps to hook on to the tabs on the lower rotator fastener. The key is to pop the fabric seat up into a cone, so that you can see what you're doing.
Feb 07, 2010 | Evenflo Baby Gear
Seat removal I bought the Little Einstein exersaucer used without directions and we need to wash the seat. Is there a trick to removing it?
Try holding the exersaucer down with on hand and pulling up on the seat rim with the other to remove seat then flip over to snap off fabric.
Apr 13, 2009 | Baby Gear
How to remove the seat cover on exersaucer
Hi, all the way around it are plastic bits sticking out and the seat cover is clipped onto the plastic bits, just lift them off one by one, all the way around. then when your done clip them back in again. hope this helps.
Mar 09, 2009 | Evenflo Toys
I have a older exersaucer made by evenflo and i dont know how to put the seat back on
original instructions for any exersaucer
https://plweb.evenflo.com/ShowDocument.aspx?ManualID=234
25702569.pdf
Sep 10, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Exersaucer 605859P1
When I had an exersaucer for my kids I had trouble putting the seat cover back on too. The cover on the one that I had wrapped around the circular rim that spins when on. There should be some hook like circles on the inside to hook the cover back on... then you press firmly to put the seat back in place... some have clips too. Mine always went in easy with a firm push down and clipped onto something rather there, never knew what I did, just press down FIRM!
Jul 16, 2008 | Toys
Old evenflo exersaucer
25702569.pdf
Jun 03, 2008 | Evenflo ExerSaucer SmartSteps ABC Stroller
Exersaucer seat
Evenflo - Exersaucer Instructions
25702569.pdf
Dec 30, 2007 | Evenflo Baby Gear
Baby Einstein Around The World Discovery Center Logo
1,178 people viewed this question
Top Baby Einstein Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Baby Einstein Toy Expert? Answer questions, earn points and help others
