Question about Dunlop Crybaby 9v Ac Adapter W/5.5mm Tip Ecb03
My power conditioner will not power my cry baby, unless i apply pressure to the 9v adapter on the wah.
  • Dunlop Master
  • 5,603 Answers
If you mean applying pressure to the power connector on the pedal, a COMMON problem is that the soldering of the connector inside has broken loose or there is a crack in the circuit board inside. Open pedal and inspect for these problems.
Posted on Mar 21, 2011
Which is the best wah pedal for my electric guitar?
As per my experience, I can suggest "Dunlop 535Q Cry Baby Multi-Wah".
It delivers a smooth and clean sound.
Its effects and features are very versatile and it's easily workable for gigs or music jams.
It allows selecting the frequency of the effect as well its range.
You can check its review in this link:
Best Wah Pedal Top 7 Best Wah Pedal And How to Find It 2017
Feb 22, 2017 | Electric Music
Keyboard AC Adapter
If thje voltage is the same, the current rating is fine at 1000-1400 mA. The accessory will use the amount of current it needs and the fact that there is more "available" does not mean it will use it. The higher current rating will not ruin the equipment. Just make sure the voltage rating is the same. Cheers!
Mar 09, 2014 | Casio AD5 Keyboard AC Adapter
BOSS TU-3 Tuner will not work with power supply or battery
It was probably connected backwards in polarity from a power supply which burnt a diode. These things have backwards polarity of 9v adapters which means positive on the outside of the plug and ground in the middle, unless you have the original boss power supply.If you have a generic power supply, cut the plug off and switch the wires and try it.
Mar 01, 2013 | Boss TU3 Tuner
I have a CryBaby 535Q for repair, but everything is microelectronics and can't see if something is blown. The wah sound does not activate with the switch activation.
Check the switch itself... they OFTEN get broken mechanically... far more than the electronics failure. Use an ohmmeter to check the switch. Second most common failure is in the power adapters or use of the wrong adapter.
Jun 24, 2011 | Dunlop Manufacturing Dunlop Crybaby 535Q...
Hi there, i got a 5150 half stack amp and the evh wah pedal, my problem is when i engage the pedal comes a terrible hum, i already change the cables, 9v battery and the ac adapter and the big noise...
WHY are you using a battery AND a 9 Volt adapter? This is an either/or thing. Chances are you have a defective ground someplace. Use just the battery and try it... If the hum is gone, the adapter is NOT compatible with the pedal. A lot of hum problems occur because the guitar is near a source of magnetic fields, such as an amp. An embarassing thing is for a musician to reverse the in and out connections to the pedal... it will have the symptoms you have mentioned.
Apr 24, 2011 | Dunlop EVH Wah Wah Pedal Wah
Dunlop Crybaby 9v Ac Adapter W/5.5mm Tip Ecb03 Logo
66 people viewed this question
Top Dunlop Music Experts
Michial Gueffroy
frankrome
rhodesworks
Are you a Dunlop Music Expert? Answer questions, earn points and help others
