The fireplace is brand new. When the store owner delivered it, it instantly started making a "noise" like there was a part loose. It hasn't gotten any better. Help!
    Brigadier General:
  • 4,736 Answers
If it's an Electric Fireplace, what you hear is the flame effect rod that's rotating, when you have the flames ON. It's probably out of place from shipping. If you have your Owners Manual, it will tell you how to access the light bulbs, which will give you access to the rod.
Hope this helps solve the problem.
Posted on Mar 21, 2011
Hunter Douglas fan humming noise
Which make/model do you have. If you bought a store brand ( Home Depot or Lowes ) it's a low-end Hunter. All you can do is take it back & get a new one and hope it's better. You can also try a fan control and see if that helps. Remember, you get what you pay for!
Jul 04, 2013 | Dryers
Noisy fan on electric fireplace
My recommendation would be to contact a fireplace showroom that sells electric fireplaces. It would be best if you could inspect your fireplace for the sticker that identifies the fireplace's brand and model#. The primary concern is contacting a showroom that is able to order parts for that brand...
Mar 17, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
I cannot get the fireplace to light up or make crackling sounds on the Barbie Dream Townhouse.
The fireplace most likely came loose in shipping. If you can get your fingertips behind the fireplace and pull if forward a bit.... then it is loose. The is a bar/clasp behing the fireplace the top needs to rest/attach to.... lift up and push back on the fireplace until it 'clicks'. (you will feel it when it sets in properly) One attached correctly to the wall... when you push button to make the TV go up - the fireplace also lights up and makes sounds.
Dec 24, 2010 | Mattel Barbie 3-story Dream Townhouse...
Stove is brand new. turned oven on for 30 minutes for initial burn, open door, but it won't shut completly, why?
You don't provide a make or model number, but if it's new, look in the Owner Manual for door malfunctions. Call the store where you bought it and tell them of the problem.
Dec 18, 2009 | Ovens
MY washer starts grinding when it starts a cycle
OK, are you certain that the shipping bolts were removed when the washer was delivered and installed? I've had folks that complained after 3-4 years that they're front loading washer was now making all sorts of strange noises when their kids came home from college and really stuffed the washer with clothes, etc.
Check the installation and owners manual for the diagram that shows the shipping bolts that should have been removed from the rear of the washer when it was installed in your home. There are usually 2-4 of these, depending on the brand/model of washer.
If the shipping bolts have been removed (all of them!) then you can pull the washer out from the wall and see if there is something that might be hitting the drive belt/motor underneath the washer. It's possible that a tub suspension spring(s) and/or pulley(s) may have come off their mount causing the noise.
Another thing to look at is to see if the pulley on the motor shaft has come loose and might be causing the noise, as it might have worked loose but still catches on the keyway in the shaft enough to still function.
I usually pull the unit away from the wall with the hoses hooked up so I can remove the rear cover and watch everything while I run the unit through a short wash cycle. That is a quick and easy way to see what might be causing the noise. From there, you can start to focus in on different areas to verify or eliminate them as the noise source. Of course, it goes without saying, be very careful not to get your hands caught while the machine is running and unplug it before you reach in and start feeling around the unit.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Kenmore 80 series will fill, agitate, but not drain or spin... I need a new lid switch. Is there any way around it until Monday when the appliance parts store opens
Yes these some pleaces open but before you call be sure to have handy the brand n model # so they can better assist you.
(877) 477-7278 Washer and Dryer parts delivered overnight... Hope this works for U "Was this helpful?"
May 09, 2009 | Kenmore 22622 Top Load Washer
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
