Question about Motorola Mobility ROKR E1 Cellular Phone
My motorola e1 fall in water and when am trying to on it but it this not coming
  • 19 Answers
If your phone is wet,do not try to switch it on before you dry the battery and phone separately,they need to dry on natural air,that means that you need to wait for availe.back cover need to be open,ofcourse.
Posted on Mar 20, 2011
I have a buamatic bdw45.1 an it will not start taking in water and then comes up with error code e1
Ok first check under the sink make sure the supply valve is on if so there are a couple things that it could be 1 the wash timer, 2 the electronic water shut off valve which is located under the machine which supplies the washer with water check it for voltage and resistance on the coils to see if it is opening and operating proper. 3 check to see that the float in the bottom of the tub is not stuck up and that it is able to fall back down easily when raised and released
Apr 06, 2012 | Whirlpool Dishwashers
Motorola rokr e1..all of keypads & joystick are not working...
open up and clear for moisture/ sweat on the pads. use a hot air blower (Hair Heater) to warm up the board and dry. Good Luck
Jun 28, 2010 | Motorola Mobility ROKR E1 Cellular Phone
How do i reformat motorola e1 rokr? im having problems with sending txt messages it hangs up
you need p2k tools and flash file for your motorola rokr e1. go to www.modmymoto.com and download this file or email me at tsarlee420@yahoo.com for assistance
Apr 01, 2010 | Motorola Mobility SLVR L7 Cellular Phone
LG dishwasher error code E1
E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
Nov 21, 2017 | LG Dishwashers
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Mar 21, 2008 | Samsung WF337AA Front Load Washer
Motorola Mobility ROKR E1 Cellular Phone Logo
20 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
