Question about Whirlpool Microwave Ovens
Cold air only - Whirlpool Microwave Ovens
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Posted on Mar 20, 2011
Galaxy microwave model 85100
If your microwave is ducted to the exterior the cold air could be from the outside if the backdaft damper is not functioning properly. If you have a HVAC system, the return air process can be pulling outside air through the hood making the condition worse. The microwave damper is usually on top of the microwave unit at the exhuast opening. Maybe some greasy dust is preventing the damper from closing all the way.
Nov 30, 2013 | Microwave Ovens
Frig or freeser not cold
If it is your freezer, check to make sure that the air vents inside the freezer are not blocked by food. Putting too much food in an blocking the air vents will prevent the freezer from freezing. Air needs to circulate inside the freezer for it to work properly. This can also cause excess freezer ice collecting on freezer or in foods. Dust and lint will collect under and behind a frig. Pull the frig out from the wall, unplug it. Check for lint under and on the back of it. If it has accumulated some, vacuum it all off and plug it back in and wait a while to see if it gets cold. The fan pulls lint and dust under the frig and it stops the cooling system. If this doesn't work, it may need the freon (can't spell it correctly) stuff replaced. If these don't work, you need to call
Feb 15, 2013 | Microwave Ovens
Freezer working fine but fridge not gettind cold.
The first thing you need to check is whether the fan is operating, moving the cold air from the freezer to the refrigerator. If it is operating, you should be able to feel air flow in the refrigerator when the fan is operating. If you don't but the fan is operating then the cooling tubs are probably clogged with ice or frost.
Jul 20, 2011 | Smeg Microwave Ovens
Freezer works but frig not cooling
if you were to reach your hand towards the rear inside the fridge area can you feel cold air blowing into the refrigerator side if not this could either be due to the fan inside the freezer area not working or there is a small door that is controled by a thermostat inside the ceiling of your refrigerator this thermostat when it reaches a tempreture that is to warm it opens a small door in the rear that connects to the freezer allowing cold air to come into the refrigerator side when the refrigerator becomes cold enough the thermostat then shuts the door. You could also have a defrost issue inside the freezer area in which u would need to remove the rear panel in the rear of the freezer in order to assure you did not have this issue. If you remove the rear panel and you see any ice build up on the evaporator coil (note this is also where the fan that blows the cold air into your refrigerator is located)you would have a defrost issue. If you remove that rear panel and find any ice build up message me back and il instruct how to fix but first check to assure you have air blowing into the refrigerator side. If you dont then you have to diagnose which is causing the issue either the fan which you could hear if you listened inside of the freezer area or the door itself is not opening due to a malfunction with the thermostat if you have any further questions message me back and please also remember when our chat has fully conlcuded to rank how this opinion has helped it allows me to continue helping others in similar situations Thanks
Rick
Jun 24, 2011 | Microwave Ovens
My whirlpool fridge (model ED22TOXGW00) does not keep the food cold enough.I have the temperature settings set to MAX and it's still not cold enough. Seems like the motor is not running as often as it...
Have you checked the cooling coils to make sure they are clean and air can flow through them? Are the coils in the freezer frozen up? full of ice?? Must have air from from freezer to cool refrigerator.
Aug 20, 2017 | Microwave Ovens
Have water dripping into refridgerator from cold air vents
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 07, 2011 | Microwave Ovens
Fridge section of fridge freezer not cold despite turning thermostat to max. Freezer section appears to be working fine.
Make sure that if it has a "colder" knob in the freezer section that it is not set all the
way over to coldest. This blocks all cold air entering the lower compartment when
set this way. It actually has been eliminated on some models.
Also you may have ice buildup in the stack assembly that feeds
the lower compartment or even a frozen upper compartment behind the back
panel of the freezer limiting air flow to the lower compartment. Make sure to unplug unit if service is necessary in these areas. I hope this is helpful.
May 02, 2011 | Microwave Ovens
Freezer side of appliance is fine but the fridge side is warm
open your freezer and see if it's blowing cold air,or if it's just cold,if it's not blowing cold air it's probably the fan, u will find this right behind the vents in the freezer,remove vent in freezer there should be a fan if not running replace this should resolve your problem
Apr 03, 2011 | Whirlpool Microwave Ovens
My Microwave vents are letting in cold air during the winter
The installation manual should help you deal with these issues. If you don't have yours, you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P641-60.PDF
OR
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8101P710-60-R1.PDF
As a bonus, you can also get your owner's manual here;
http://shared.whirlpoolcorp.com/assets/pdfs/literature/8112P268-60B.PDF
One important thing is to make sure you have a good vent door on the outside of the home. If that's not working right, it allows mor cold air in. Also, the pipe should be insulated.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 01, 2007 | Maytag MMV4205 Microwave Oven
Cold air from outside coming in house through vent
Sounds like your damper (flap) outside is working, and that's probably the first thing to check. Wind may be also pulling the damper open from time to time. Hopefully the pipe fitting is sealed, and the pipe is insulated anywhere it runs through any unheated portion of the house. Some amount of cold air getting in will be unavoidable. The best bet next might be to look over the two pages in the installation instructions that deal with outside venting. If you don't have the installation instructions, you can get a copy here: http://www.geappliances.com/service_and_support/literature/ Then if you don't notice any obvious problems with the installation, it may be time to contact the installer for their two cents.
Feb 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
14 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
