Question about Milwaukee Tool Milwaukee 6225 6/5 - Amp AC only Portable Band Saw
The blade keeps running off the wheels. I have replaced the tires and guides. Is there any kind of adjustment to true the wheels
  • 2,176 Answers
No there isn't, what you need to check for is loose axles (the stud with retaining ring), and also check the front housing for misalignment. If it has gotten hit it will cause the blade to run off. What you can do is take the wheel cover off and loosen the axle and put a shim under the backside to tilt the axle forward and retighten, this will usually cure the problem. Also look at the wheel bearings for wear. Let me know if you need more assistance and if I have helped you with yuor problem would you please vote accordingly, Thanks
Posted on Mar 21, 2011
Delta 28-160 3 wheel band saw and the blade slips off after 1-2 rotations of the wheel. I have replaced the tires with the blue tires.
one of the wheels will have an adjustment that aligns the wheel correctly
bands/belts always run to the highest point so one of the wheels is not true and presenting a high point causing the blade to run off
Sep 03, 2016 | Olson Cool Blocks 5008 Delta 28-180, 160 &...
Metabo baas 317 precison band saw keeps throwing the saw blade off.Tried various adjustments as per the manual.......no success
Here we go. I looked online for this saw, and it looks to me like most others. First, be sure you blade is not stretched from over-tightening or worn out. Either of those can cause your problem. Then, take your blade off and visually align the wheels , or even figure out a way to measure the wheels to see if they align. Then install the blade and turn it by hand to see if it is tracking true. You may need to do this for a while. One it turns true by hand (make the adjustments of the top wheel to cause it to be straight), then you will need to set the guides to support the blade in it's correct position. The should be guides above and below the table, probably both behind the blade and to the sides of the blade. As many as 6 adjustments, on some machines.
Usually the guides should barely touch the blade to hold it true.
Be blessed.
Feb 09, 2014 | Metabo Saws
Blade on my 9 inch mastercraft band saw does not tension properly
Check if the tires are align. The blade must be on the center of the tires. Check for both tires for wear . You may want to
check the blade guides too. They must not touch the blade. I just purchased new tires on www.bandsawparts.com for a
friend. We've learned that his tires are well worn out that's why the blade keeps on coming off on the wheels.
Mar 07, 2013 | Saws
I have a new JET JWBS-10OS. I bought it rather than a scroll saw because it is more versatile, but I do need it for scroll work. I purchased a 1/8 inch blade and had trouble with the installation. The...
I'm not a Jet tech, just a bandsaw owner.
First, when you are adjusting the tracking knob, are you turning the wheel by hand for several revolutions to be sure which way it is running before making another adjustment? After tweaking it, you should turn it a bit to let it settle in. Also, be sure to tighten the adjustment knob down before turning it on.
The bearing guides have more adjustment places than just the finger adjusters. On mine, a Steel City, I can move the entire guide holders back and forth, and can also move the entire guide set up back and forth. The guides are there to keep your blade from having too much movement while cutting. They are not supposed to actually touch the blade though. I adjust mine with a dollar bill between the guide and blade. If you have one guide that isn't exactly perfect, don't worry about it. The blade guard will also keep the blade from wandering.
I've never used my bandsaw for scrolling work, so am not familiar with the 1/8 inch blade. Should work if you can get your tire adjusted correctly.
Good luck.
I hope this helps. If it does, I'd appreciate a vote or comment. Thanks,
Handie Andie
Apr 03, 2011 | Jet 707200 10Inch Band Saw
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
How do you keep the blade on the wheel? Mine keeps coming off. It is a Rockwell product. The blade came off while I was using it and I can put it back on both wheels but as soon as I turn it on, the...
Sounds like it could be quite a few different things. My suggestion is to go to you tube and look at Band Saw setup. I haved viewed the one from the wood whisper and it covers set up in detail, there are also other videos that may help.
Sounds like a setup problem - wheels,tires,guides,and even blade tension can cause this.
Does the blade track true when turning top wheel by hand?(unplugged of course)
Is the blade tension correct?
Are the tires in good shape?
Are the guides and back up bearings set correctly?
I hope this will get you headed in the right direction.
Nov 14, 2010 | Delta Rockwelldelta 14" Hinged Wood Band...
Can't get the blade to stay on track
There is an adjustment you can make to the top guide wheel to make the blade stay on track. There is a screw with a lock nut just beneath the main bearing for the top wheel that is used to "tilt" that wheel to allow the blade to stay where it is suppose to. This needs adjustment periodically due to normal wear in the bearings or maybe due to a blade which is made a little different than the last one that was on there. Loosen the lock nut, then turn the adjusting screw to tilt the wheel in the direction needed to keep the blade on. Not much adjustment is usually needed. After turning the screw, jog the motor on briefly (with the blade on) and check how it runs. Keep adjusting until you get it running true. Lock the nut and you should be good.
Good Luck. Be Careful while jogging the motor to check the runout, as you will need to do this with the guards out of place.
Dec 09, 2009 | Northern Industrial Tools Electric Meat...
I need a manual for an old Sears Band Saw Model #534.01120
Does it look like this? Unfortunately, they don't have a manual that I could find. But you might like to post your request in the forums there, as they get some traffic from aficionados of old tools with wile and know how.
It might help you also to google Dunlap & PowerKing for the manual.
As far as tuning it up goes...
Check each of the wheels' "bearings" to begin with, to ensure they are running smoothly and as true as possible, without end play or wobble. Then use straightedges and flat jointed boards to line up the three pulleys as much in a single flat plane as possible, by shifting shims, etc. (It may behoove you to remove the table out of the picture to begin with, if possible, so you can get the wheels lined up well with one another, then replace the table once the blade will track.)
The adjustments on a three wheel system can be a little more delicate and temperamental than on a standard 14" bandsaw, so be moderate in your tracking adjustments, and crank the wheels by hand to begin with as you work the tension up on the blade, checking constantly to keep the blade running as close to the center of all three tires as possible. Don't worry about the blade guides at all until you get the blade running on the wheels well. Then move the backed off guide blocks and backing bearings into place. They are meant, after all, to keep the blade from deflecting, not to force it into position.
That's my quick advice for how to tune it up.
Good luck. It looks like a beaut!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 22, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
My center piece on the table will not line upor go back into the table top of my Delta 14" Bandsaw when I use a bigger blade. What should I do to correct?
Can you turn it 180 degrees so the slot faces the other direction?
If not, (because of the notch), you'll need to readjust your guides...You probably should anyway..
Begin by backing off the bearing behind the blade that keeps the blade from riding farther back into the outfeed table. Then loosen the guide blocks and adjust the upper wheel so that when the blade tracks on the tire, the cutting edge is just forward of the center of the tire, (where the cutting edge of the narrow blade tracked). Once you have the blade running smoothly, bring the guide blocks in close to the sides, and adjust the back bearing so it just barely spins when the blade is freewheeling, and provides support when a cut is made.
You may have to adjust these instructions slightly to account for what's available with your saw, but that's basically the method for making the blade track in the center of the knockout.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 12, 2009 | Dewalt dw3988 14tpi portable band saw...
How do i take off and replace the blade on my berkel bandsaw
There should be a blade tensioning adjustment on the back of the upper wheel. You need to loosen this until the blade is loose, then open both front covers and possibly remove the guard, then install new blade and retension.
Then adjust the tracking and guides as follows:
Before tuning it up, loosen the guides and wheels away and square the table to the tensioned blade. Then follow these steps in order:
  1. First, adjust the upper wheel so the blade is tracking at the center or just to the front of center of the wheel tire. (You can see this with the cover removed, and adjust it with the nut/wing nut in the back).
  2. Now, make sure the blade guides are adjusted so they don't deflect the blade to either side (when looked at from the front), so they contact the blade just behind the gullet of the teeth, but not against the hooked teeth themselves, and are just tight enough to allow the blade to run freely (including the weld). (If your guides are worn and out of flat, you may wish to dress them on a sander before adjusting them against the blade.) Adjust the guides both above and below the table. At this point, ensure that the guide bar moves up and down easily and locks into position without torqueing the guides against the blade.
  3. Finally, adjust the bearings behind the blade, so they just kiss it, and turn freely when you revolve the bandsaw wheel. They will support the back of the blade when pressure is applied against it during a cut, and help immensely to keep the blade tracking straight.
At this point, check the cut by trying to follow a straght line penciled on a board. Some blades will naturally tend to veer slightly on a diagonal, depending on how they are sharpened, and you may have to adjust your fence to compensate for this "drift".
But if you follow the steps outlined above, and have a good sharp blade to begin with, you should be able to split a line.
Mar 23, 2009 | Saws
Milwaukee Tool Milwaukee 6225 6/5 - Amp AC only Portable Band Saw Logo
183 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
