Question about Samsung RS265LABP Side by Side Refrigerator
I have a Samsung RS265LABP COMP#MK1183-L2U BOM name R165LABP/XAAI seem to be haveing a controll problem I should be abel to control the tempetures we like to keep the fridge side at 34 deg. f. and the freezor side -4 or colder with the fridge side being the more important to us seems like the temps are not staying at set temps I understand if the doors get opened a lot the temps will go up we dont have kids in the house just me and the wife and her sister and we have reframed from geting in and out while trying to see what the fridge is doing . I noticed the temp went up to 46 deg and the temp was set at 34 not 46 i reset again set the power cool and power freeze to get back down to disored temps let it do its thing took it more than normal to drop temps. I have checked for loose plug connection and any blocked air flow in and out of refridgerator. Can anybody give me some information to help me with this issue thank you ak
Same problem here, I unplugged it and was a quick fix but then went to the same sht again. Please help!
Posted on May 15, 2011
Samsung rs261mdpn
Replacing the main control doesn't fix anything on the display they have separate functions. You need the bom number to find the display board it should end in /xaa or something like that
Nov 06, 2013 | Refrigerators
No ice
Almost certainly you need a new icemaker. What is the model number of your fridge? The model number is normally inside on the left side of the fridge and also has a BOM number that ends in /XAA or /AA the BOM number would be more helpful than the model number.
Mar 13, 2013 | Samsung Refrigerators
RS265LABP freezer works but fridge doesn't.
if the evap fan motor isn't running then most likely this is you rproblem
Nov 25, 2011 | Samsung RS265LABP Side by Side...
My refridgerator (Samsung side by side RS265LABP) is starting to act funny. The temp on outside reads 36 degress; howver it is much warmer to touch on the inside. What can I do to help fix this problem?
See to it the temperature control is working correctly, if it is not then that's will happen. Set temp control to low temp if it doesn't cool and it is warmer then the controller has some problem. Call a service technician to replace that or if you can do it yourself just replace it with similar rating and size, pay attention when you disassemble it.
Good luck.
Jun 22, 2011 | Samsung 26.0 Cu. Ft. Side-by-Side...
For no reason, my freezer went up to 56 degrees in a matter of 5-6 hours. I pulled the plug like the manual states because the temp was blinking. That solved the blinking. In 6 hours the temp dropped to 44...
You have either a sealed system problem or a control board problem. It's difficult to know which is which. You will need a qualified technician to determine what the problem is.
Good luck
Jun 17, 2011 | Samsung RS265LABP Side by Side...
Model rs2544sl no cooling
Try resetting the frig by holding the power freeze and power cool buttons down at the same time.
Jun 12, 2017 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RSH1DTMH fridge/freezer - Left hand side keeps freezing over in the fridge,by the deodorizer. What causes this?? Please help - Ty
Usually, there is an issue with one of the following:
* electronic temperature control located in fresh food compartment
* defrost thermostat and/or heater(s) located in freezer compartment
Contact an appliance service company.
Feb 16, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung control panel says cold but fridge is warm
have you checked to see if the interior blower fans are working?
I'm not a tech, but it seems to be my problem
Aug 17, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Fridge evap freezing over
A friend had a similar problem; he found that the compressor was
getting overheated. He fixed an axial-fan inside the control box
to keep the compressor cool, and things worked out OK.
Nov 28, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Nov 20, 2007 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS265LABP Side by Side Refrigerator Logo
154 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
