Question about GPS
Is it possible to use garmin 350 and charge in the car at the same time without a mount only using cig. lighter cable?
    Genius:
  • 1,114 Answers
If you are able to find an adapter that will fit the charging port, then it is possible.
Posted on Mar 20, 2011
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
HOw do you charge it?
This unit comes with a charger (AC). There is alxo a car charger. Both have a USB connecter that plugs into the side of your unit.
Sep 20, 2011 | Garmin nuvi 350 GPS Receiver
Garmin will not charge using car charger. The fuse is intact. It will charge using usb port per computer. Any ideas?
meter out the cable and see if you are getting anything out of the car charger, of course while the car is running. If you are getting no juice, then either the fuse for the cig lighter is bad or the car adapter is bad. either way, easy fix. Good luck!
Oct 23, 2009 | Garmin StreetPilot c340 GPS Receiver
Low Battery after using it
I had the same exact problem about three years ago when mine was new. I sent it back to Garmin and it took some convincing on my part to get them to replace the mount and cable for the car. The first time I sent it back they only wanted the unit back, not the mount. Same problem when i tried the replacement unit. I called service again and told them that I was sure it was in the cable from the cig. lighter socket and that I was going to send the whole system back. They said ok and when I received it back from Garmin the second time I had anew mount and it has been fine since. By woodtick
Mar 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin NUVI 660 power problem.
To charge a nuvi, use one of the following methods:
  1. Connect the nuvi to the suction cup mount and the vehicle power cable.
  2. Connect the USB cable to the nuvi and the computer. The computer will charge the nuvi as long as the computer is on. However, the unit will be in Mass Storage Mode and normal operation is not possible.
  3. Connect the AC power cable and the nuvi to a wall outlet.
Please note: All of the nuvi series will come with a suction cup mount and vehicle power cable to charge the nuvi. However, only some of the nuvi models will come with an AC power cable and/or USB cable. If they did not come with the nuvi, they would be optional cables and would be a separate purchase. Garmin only recommends using an AC power charge that is purchased from Garmin. Third party power cables may not charge the nuvi. These cables may be purchased from Garmin or Garmin's dealers.
Oct 11, 2008 | Garmin Nuvi 660 GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Aug 02, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
Battery charging
Cig-lighter offers 1A current. The battrey will be fully charged for 4 hours if the unit is not used.
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Can I find a copy of the Garmin Nuvi 350T manual online please?
Yes. There are 3 ways to charge the Nuvi. Computer USB cable, 120VAC transformer wall plugin, and the cigarette lighter DC 12V plug for your car.
May 24, 2008 | Garmin nuvi 350 GPS Receiver
I can't charge my GPS while I am in the car
Verify that the car cigarette lighter outlet is working. Do you have something that you could plug into the lighter like a light?
With the car running plug the Garmin into the cigarette lighter outlet. Does it come on without pushing the ON button? If the answer is no then there is either a problem with the cable or the cigarette lighter outlet. It should come on by itself if the lighter is working. Also are you using Garmin cables and DC adapter?
Jan 31, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
15 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
