Question about Dishwashers
Dishes dont Dry .. Always coverd with moisture and foggy
  • Kelly
    Kelly Mar 20, 2011
    This can be caused by a few things. Blower fan, Heating element, heat / air dry switch (if so equipped), wiring or blocked door air passage. What is your make and model number please so I can look up your model?
    Thanks,
    Kelly
  • Dishwashers Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 20, 2011
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
My watch face has suddenly become watery and foggy - I don't remember letting it get wet - please help
You need to remove the back plate and leave it sit in a warm, dry area for 24 hours to allow the moisture inside the watch to evaporate.
Nov 11, 2010 | Watches
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    Is there a heated dry feature on the Dacor? When I open the door at the end of the cycle there is still a lot of moisture and water droplets in the unit.
    Below is a website with information about your dishwasher. It says it has a condensation dryer which means it dries the dishes using the heater coil in the bottom of the unit. This is a very slow process which continues to dry even after the unit has run all of its cycles. Usually over night they should be dry but any puddling water left on the dishes such as an over turned mug or cup will still be left on the dishes. The drying is done in this way to prevent damage to delicate glassware or melting plastic items in the unit. There is no dishwasher available that can fully dry the dishes due to the possibility of damaging your dishes.
    http://www.homeeverything.com/web/sitefiles/product-9166/ED24.html
    Sep 28, 2010 | Dacor ED24 Built-in Dishwasher
    Foggy headlight lens replace driver door mirror
    Foggy headlight lens is from water ingress and gets trapped in there, the easiest way for you is to unscrew the back of the headlight assembly and get a hair drier and just dry out the head light, it may come back after a few rains,, other wise undo the screw holding the headlight unit, disconect wires and remove unit, I have the submerged unit into water watching where air bubbles come from then apply a small bead of water proof flexible sealand or silastic around the edge where the cover and lense meet, Dont try to take the lense off you will break something. Dry out completly and use hair dryer agin on low setting to make sure all moisture is gone and reassemble back onto vehicle....
    Jun 21, 2010 | 1999 Mercury Grand Marquis
    It looks like it's foggy inside the scanner and the images also look the same once scanned
    Sounds like moisture built up under the glass. Move the unit to a dry warm place and let sit (with cover open) for a few days. You can also use a hair dryer set on low to speed up the process. This moisture can be caused if the unit was in a cool or cold area then moved into a warmer area.
    Feb 22, 2010 | Epson Perfection 1260 Flatbed Scanner
    Wont clean dishes,white streaks in washer,foggy glasses
    The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
    Feb 17, 2010 | Viking DFUD04 Built-in Dishwasher
    My new Kenmore Elite panel ready dishwasher leaves wet
    You need only enough space so the door does not rub when opened. If the unit is too far back under the cabinet the countertop (if wood) can be damaged by the exhausting moisture. The dry feature on the newer models is just as you describe. The moisture from the hotter dishes evaporates and is condensed on the cooler walls and door of the wash tub. Dry dishes wet tub is normal.
    Eric
    Jan 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
    I have a scope on a 222 and it was raining yesterday and now the scope is foggy in the inside. how do i get it to dry out
    Generally, you can remove the rear eyepiece and letting the moisture dry out using a hair dryer. Put it back together while it is still warm.
    Dec 04, 2009 | Weaver Optics
    The dishwasher is not dring the dishes
    How old is this unit? Are you removing the dishes at the end of the cycle or leaving them? Are you filling the rinse aid dispenser? The new dishwasher will not dry properly without rinse aid. Dishes have to be removed at the end of the cycle because a dishwasher is a moist environment moisture will reform on the dishes if left with door closed. A dishwasher does not have a fan to move the moist.
    Jan 25, 2009 | Frigidaire 24 in. FDB635RF Built-in...
    Dishwashers Logo
    Top Dishwashers Experts
