Question about Dryers
Flame comes on then goes off - Dryers
  • Kelly
    Kelly Mar 20, 2011
    This is usually caused by a flame sensor failure. Without a make and model number I can not be 100% sure. What is your brand name and model number of the dryer please?
    Kelly
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 20, 2011
My rheem conquest 80 furnace comes on and 5 seconds later the gas goes off, it just keeps trying to come on.
This typically sounds like a flame sensor issue. Now, just so we are on the same page, the flame sensor( flame rod), its the rod that is opposite of the ignitor. Now that we have confirmed that, try cleaning the rod with some fine sand paper, nothing too gritty. the goal here is to try to clean any carbon buildup on the sensor that has created all these years of being directly in front of the flame. carefully. So give it a good cleaning to make it look new again but care not to clean too hard so you don't break it. Its best to take the flame rod out and do it and re-install it. If that does't work, try replacing the flame rod. The controller isn't getting any signal back from the flame sensor signifying flame is present. Try this first. Always turn power off when working on electrical equipment.
Dec 03, 2017 | Heating & Cooling
Whirlpool dryer heating sporadically?
Remove the lower front panel and turn dryer on. The ignitor should glow bright orange first. After Ignitor glows brightly the next thing will be the flame lighting as the gas valve opens with a click. All this should happen within about a minute or so.
If flame comes on but goes off quickly It's likely one of the Gas valve coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The coils are purchased as a kit.
If ignitor goes off and no flame comes on the coil kit is likely needed because one coil is fully broken inside its case. If flame goes on but shuts off shortly the problem is as described above and the kit is needed.
There is a flame safety assembly on the can above the burner. If the airflow is poor. the flame tip may activate that safety and turn the flame off. Or the flame switch may be open and not allow the flame to come on at all.
The Flame switch can be tested for continuity with an ohmeter but the valves may ONLY show bad with power applied and can not be tested with a meter as they will test good.. Good Luck
Nov 18, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Igniter comes on and flame comes on. Igniter goes off and 40 seconds later, flame goes out. About 40 seconds later, igniter comes back on and then flame comes back on. About 40 seconds later, flame goes...
It sounds like the sensor that determines that a flame is present is not working. Find this sensor by looking for a device that is exposed to the flame and has wires going to it. Check this sensor and replace if necessary.
Sep 12, 2013 | Dryers
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
Fires and runs for a few minutes then shuts off tries to re fire a few times then goes to 2 blinks=cannot sustain or detect flame.
There is a flame sensor located in the last burner that lights up. It is either not seeing flame or not getting flame to it within a certain time. Check the wire that comes from it and goes to the circuit board for a bad connection. Check any ground wire connections for a bad connection. Pull out flame rod (sensor) and polish it with a scrub pad or soft wire brush. If none of these recommendations help, replace the flame sensor. Make sure the flame travels to the last burner, if not, clean the flame tray that allows the flame to go from one burner to another.
Feb 13, 2011 | Mr. Heater MHU75NG
Inductor blower comes on and runs then the ignitor glows flame comes up and burns for approx. 10-15 sec then goes out then fan comes on. Model number is PBKMLB12N0B0F I believe this is a goodman furnace.
I cleaned the sensor that was at the the right further most burner on my Goodman and it worked. got the answer to my problem here at fixya. My burner flame only lasted 5 secs before it shut off. Thanks to all who took the time to send me a response.
Nov 13, 2010 | Goodman Heating & Cooling
The flame goes out after about 30 seconds. I have
one of the thermal sensors may be bad.
you may also have a faulty ignitor even though it glows it maynot be drawing enough current to keep the regulator open
May 28, 2010 | Maytag Neptune MDG7500AW Gas Dryer
Gas dryer flame comes and goes everything else
you are obviously having igniter problems Call an authorized gas appliance serviceman before you have more very serious problems
Dec 19, 2009 | Dryers
Dryers Logo
Top Dryers Experts
