Question about Amana ARB220ZCS Bottom Freezer Refrigerator
I have the Amana ARB220ZCS fridge and yesterday it just stopped working. This light is sill on but it is not getting cold, the fridge or the freezer. Thanks James
  • John Tripp
    John Tripp Mar 20, 2011
    This question has many answers and will take a little time to go through and solve. If you want assistance I will be happy to help you. All you need to say is OK and respond to my writing here. I can give you the manual but I will not be able to post the manual here, Thanks, Sea Breeze
  • Amana Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
The refrigerator portion of my Amana ARB2217CW stopped cooling (the fan is still running), but the freezer drawer portion still works fine. What can
most likely you have a bad damper,go here to see it
http://www.repairclinic.com/PartDetail/Damper/67003410/1025326
all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air to the fridge section and it goes through the damper,when it gets cold enough in the fridge section the thermostat on the damper closes the damper door,your damper broke in the closed position,this is as long as the door wasn't left open or anything like that,if it was the air ducts could have froze up but most likely it will be the damper.go here and it will show you where it is up near the light in the back and it's part number 18.hope this helps
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-ARB2217CWPARB2217CW1/1268/0161000/M0403273/00003?blt=06&prst=&shdMod=
Sep 04, 2012 | Amana Refrigerators
My amana suddenly quite running... the lights work inside but the compressor isn't running. both the freezer and the fridge are nor working.
I want you to try something but if it does not work please let me slide on the low rates. I have seen this happen a lot when the defrost timer goes into defrost the switch is in a place on timer that causes a weak timer to stop there if timer is defective. Your timer is part number Click Here=> 67001036 You will find it inside the fresh food section and behind the control panel=> ARB220ZCS_Controls In that photo you will see a number 12 and that is the timer location. Most refrigerators will have a hole going through the control panel (with plastic plug to hide hole) so you can place a flathead screwdriver inside and slowly turn clockwise. If compressor and fans come back on just replace timer. You also may have a bad thermostat. If compressor was quickly starting and then stopping I would look for something in the compressor area. But these symptoms seem to stick out for me, Thanks Sea Breeze
Jul 18, 2011 | Amana ARB220ZCS Bottom Freezer...
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Amana side by side Refrigerator model #asd2624hes is not cooling
its most likley the compressor if you wire the compressor independently and get the same sound then you will have to replace it
Sep 22, 2009 | Amana ARS2661B Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Jan 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The refrigerator is not keeping tempurature. Freezer is working fine
Either the freezer fan has stopped blowing air or the defrost timer has stopped and the airways to the fridge are clogged with ice. Only the freezer gets cold in a refrigerator. The fridge part gets cold by cold air being blown through air passages from the freezer. Good Luck!!
barneyluc
Oct 03, 2008 | Amana Refrigerators
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Amana ARB220ZCS Bottom Freezer Refrigerator Logo
120 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
