Question about LG Cell Phones
When I use my touch screen on my GS505, it doesn't respond correctly. Also all I can use is my dialer screen and when I do it's not correct I press a 9 and it shows that I pressed a seven, when I press 6 it shows 4 and when I press 3 it shows that I pressed 1. Also when you actually press a one of the numbers such as 9, it eliminates the 7, -etc. With the touch pad operating this way, I can't text or use any of my other features. Chris
  • cfinagan Mar 21, 2011
    I would like to be able to reset it, however, I can't get to the home screen. When ever you touch any button on the phone it takes you to the phone dialer page, which you can't do anything with either.
    I really appreciate your efforts with this issue, however, I don't feel that you have help me resolve anything since I have already done all the things that you have advised. My thinking was that maybe that the phone may have be smart enough to be repaired with some software keystrokes on the dialer, or a hard reset either on the inside of the casing, or with the latest technology of hooking a cable up to the phone using the computer to trouble shoot the phone and repair it. Well, I guess none of these ideas have been thought of by the manufacture. I sincerely appreciate your assistance, but I would like my account credited since your company didn't resolve anything for me. Thanks!
  • LG Master
  • 3,530 Answers
Welcome to Fixya
Sounds like you have a software/hardware problem there. To resolve software issue, try to reset the phone to factory state. From the home screen, touch the phone on the settings tab select reset settings. If same thing will happen after factory reset then the problem would be the touch screen. You might need to replace it or have it calibrated to LG repair center.
Thank you for using Fixya!
Posted on Mar 20, 2011
  • Jose Cada
    Jose Cada Mar 21, 2011
    you might need to bring the unit to LG service center for screen re-calibration. i am not aware of any key comnbination the will reset the unit.
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
Having keypad issues with my HTC EVO. It locks up and the only thing I can do is turn it off. The #pad for the phone dialer malfunctions in that it will read the incorrect numbers from the middle set
It might be a software update problem, or touch screen need to replaced, got ur dealer Incase u have warranty, they will solve it without a penny. Good luck
May 15, 2012 | Google Android
Bizhub 200 touch screen is not working correctly
Utility/Counter Details Stop00 Stop02 Maintenance Mode then touch screen adjust does not work get a new control panel try web site below Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Mar 12, 2012 | Minolta bizhub 200 All-In-One Printer
LG KS20 touch screen not responding corecttly some times.
LG KS20 touch screen SolutionGo to settings menu - Touch celebration - click correctly touch position - u see done.
or" change your PDA ( touch screen )
Dec 15, 2011 | LG KS20 Smartphone
The touch screen is not responding to any of the touches and it started as if the screen alignment was not correct like if you want to dial a number and you are pressing 8 it will write 2 but now it is nor...
i have a nokia x3-02 the touch screen seems to be out by approx 1/2 inch i.e. pressing messages gets camera, due to this fault i cannot alliange it , can suggestions
Jun 29, 2010 | Cell Phones
Touch screen doesn't respond sometimes
- calibration your phone
- if doesn.t work ,... change the touch screen
Apr 28, 2010 | Nokia 5800 XpressMusic Smartphone
My phone touch dialer /keypad not working .
my phone touch keypad is not working, so i am unable to unlock my phone, have any solutions?
Jan 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
when on your phone vertically press the track ball and your keypads will show up thus allowing you to use you voicemail commands
Oct 28, 2008 | HTC G1
Cell Phones Logo
56 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
