Question about Epson LQ 580 Matrix Printer
Where can I get table for DIP SWITCHES for Epson LQ 580?
Niteesh
  • 65 Answers
SOURCE: Epson LQ-1050 Matrix Printer Problem
1. spread som lubricant on printers rod, in which head moves.
2. change your data cable, or remove it & connect it properly.
Posted on Feb 23, 2008
SOURCE: problem with epson LQ-680
my problem is how to install epson lq680 in windows xp,before i installed but font not correct,i have not get a english word
please give me solution about this problem
Posted on Apr 05, 2009
scott4169336
  • 103 Answers
SOURCE: Need driver for Epson LQ-570e
Google epson LQ-570e or www.cnet.com
Posted on Dec 06, 2009
  • 1244 Answers
SOURCE: how to check paper end sensor for epson lq 2180
have to remove all the covers and its located in the paper load tray at the back has a plastci trigger lever and operates the internal switch what happens is the lever wears off or breaks on the end but the switch does go bad itself
Posted on Jan 22, 2010
  • 121 Answers
SOURCE: EPSON LQ 1070+ PRINTER DON´T WORK ON WINDOWS 7
Unfortunately, no Win7 drivers exist for this printer.
You are better off running a Win98 or XP virtual machine on Win7 (like in VMWare), and installing your printer that way. There's no guarantee that would work, but it's at least one more thing to try.
Good Luck!
Posted on Jan 24, 2010
My epson dot matrix printer keeps pausing and beeping
It's trying to tell you to dump it and get an Ink Jet or a Laser printer.
Ink Jet printers are about $50 - $80 @ Walmart.
Jul 15, 2014 | Epson LQ 580 Matrix Printer
I wan epson lq 580 driver for window 7 32bit
try windows xp 32bit driver
manufecturer link for further information windows xp driver will support in windows 7
tech.epson.com.au/downloads/category.asp?sCategory=Dotmatrix&id=lq580&SelOS=Y
link for download
http://tech.epson.com.au/downloads/product.asp
Sep 23, 2011 | Epson LQ 580 Matrix Printer
I am trying to send a dos file for printing to epson fx-2190. althought i have set the character table to 437-Greek my printer does not print greek alphabet
You would probably need to set the printer DIP switches to print Greek, however it is quite possible that this is not possible. Get hold of the printer DIP Switch settings and check. Alternately you will have to try the exercises using a GUI operating system to print the selected font style.
Jan 16, 2011 | Epson FX-2190 9 PIN Matrix Printer
PRINTING TWO EXTRA LINE ON @EJL 1284.4 @EJL ON EVERY FORM INVOICE AND CHECK EPSON LQ570+ RUNNING ON WINDOW 7
Windows 7 x64 & LQ-570+ ESC/P2 @EJL solution (should also work for other printers/OS, but not tested yet):
Try modifying .dpg file.
STEP 1:
Print the windows test page.
STEP 2:
There should be written the location and name of the file (Data file), so print the test page and look up the file path. It is located in the sam folder as dll (config file). In my case it is in "C:\Windows\system32\spool\DRIVERS\x64\3\".
(Sience I coulden't find x64 driver for LQ-570+ ESC/P2 I used LQ-590+ ESC/P2 Ver 2.0 driver. It's working ... )
STEP 3:
Now, when you found .GPD file, (make backup copy just in case) you have to add your computer account to list of accounts that has full controll of file or you won't be able to save changes.
STEP 4:
Delete only @EJLl 1284.4 and @EJL in line that looks like that:
*Cmd: "<0000001B01>@EJL 1284.4<0A>@EJL <0A1B>@<0D1B>t<011B>6<1B>R<001B>P<1B>(U<01000A>"
(If you delete anything else at that line it won't work ...)
STEP 5:
Save file an enjoy printig :P
If you have any question, write to riddle.xyz@gmail
Sep 01, 2010 | Epson LQ 580 Matrix Printer
Want to print draft mode in dot matrix printer in XP
Not all dot matrix printers will print in draft mode. When operating from DOS it was usually necessary to send an Esc(ape) code such as ESC @ in ASCII code. I don't think it can be done from Windows; in fact some windows programs will not even talk to a dot matrix printer. Some printers have one or two banks of DIP switches, but before changing them you need to read the manual to see what they do. There could be one which allows Draft MOde.
Sep 24, 2009 | Epson LQ-1050 Matrix Printer
I have a epson LX 400 Dot matrix printer. When i print anything from windows(XP) i see that the print come twice, ie two time print of the same matter . When i print using the print screen on dos or else...
Dear Sir,
It is problem printer resulation
please install lq 400 driver in your computer
resulation 180 by 180 then print are ok no twice
this ptinter is properly support win 98
I pray you will success
thanks
Tareq
Aug 28, 2009 | Office Equipment & Supplies
Epson LQ 580 Matrix Printer Logo
102 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
