Question about RCA L32WD12 32 in. LCD HDTV
Rca L32WD12 multi colored vertical stripes on left side of screen
  • Thomas Grice Mar 20, 2011
    It is not the connection type. This shows up even with no input. The back light is working. I have already replaced 3 caps on the power supply board. Sound works. Just a blank screen on the right side with the multi colored vertical lines on the left. Any other ideas?
    All the other caps look good. All the voltages also look good. I did turn the tv over but no change. It is looking like the screen is bad. Thank you for the help.
  • 902 Answers
If this only happens on one type of connection (hdmi cable etc) change out the connection type. also go to the menu option for your tv and re-calbrate. if neither of those work your monitor is going bad. very common on lcd screens. (hence the nature of the multi colored vertical stripes) sorry for the bad news
Posted on Mar 20, 2011
  • 1 more comment
  • brian shevack Mar 20, 2011
    seems like you know what your doing. all other capacitors ok? check voltage to the display? i would also suggest changing out the display board controller completely (if that doesnt work prob a bad screen) but it doesnt make sense since you've done 99% of the UNcommon issues with lcds. i have a really silly idea to. flip the lcd screen. see if the problem stays on teh right side even if its flipped. otherwise its the screen .
    if you have aim or skype contact me littleiceylilb to communicate faster.
    no prob. thumb me up if you feel like it . but yeah its the screen
I have an LG 2009 60ps60 plasma TV with multi color vertical lines on the left side of screen. Is there a board I can change to correct this problem??
1. Identify the TCON board.
2. Reset the Left side ribbon cables on the T-CON board
3. Replace CON board if you find a spare
Apr 13, 2016 | LG Televison & Video
Dell Latitude D505 half of screen is black with colored vertical lines.
Sounds like you have a section of dead pixels. This can happen if the laptop has been dropped a lot or stepped on or some type of impact on the laptop. This is a hardware issue. You will need to have the screen replaced. In my opinion, by the age of the laptop, its better off getting a new one.
Oct 01, 2014 | Dell Latitude D505 Notebook
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
I have a HDTV 524159 RCA, it has an hour-glass effect on both directions. On the left side, it hour-glass inward with red and yellow stripes and on right side blue and light blue stripes. It hour-glass...
Hi Sandy, the problem with your TV is called "convergence". It can be a problem with the convergence board or more likely in this model in the power supply or deflection circuits. Unfortunately, troubleshooting by a technician is required.
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Big vertical tinted stripe on screen
Need more information:
Can you isolate which color is causing the banding?
Is there something ON the lense itself?
Is the projection mirror broken or bent?
S
Dec 12, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
RCA L32WD12 32 in. LCD HDTV Logo
318 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
