Question about Zanussi Washing Machines
Hi,I need longer cold fill hose and longer drain hose for my zanussi FJR1254W model,due to kitchen refurbishment the existing ones wont reach.
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply parts direct; it's just made up of ordinary guys and gals, probably at home, with experience of addressing problems and giving guidance for free on the web ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful. Another thought- does your local hardware shop not sell such things?
Good luck,
John C
Posted on Mar 20, 2011
Washing machine fills up but empties at same time
If there are no obvious signs that the water is leaking out of the wash tub onto the floor, the cause is usually due to improper installation of the drain hose. The drain hose must be elevated prior to going into the household drain otherwise a siphoning effect will take place. A drainage standpipe or wash basin should be a minimum of 85 cm high to eliminate the possibility of siphoning.
The height of the drain will determine the maximum amount of water the washer can hold before siphoning begins.
Due to this effect, some manufacturers now place the connection for the drain hose towards to top of the washer cabinet instead of at the bottom. This then makes the actual drain height irrelevant. However, siphoning can still take place if the drain hose is sealed into the stand pipe.
Dado
Oct 15, 2014 | Zanussi Washing Machines
Front drain pipe has come off, how to refix it
Lay down the washing machine and on the underside (bottom) you can access to a filter and small drainage hose.
End of drainage hose connect to filter housing
Dado
Jan 06, 2018 | Zanussi Washing Machines
Can you put a longer drain pipe on the washer than the one that came with it?
Yes, but if you do too long you will need to upsize it... and you can't go too high with it or it will not pump out right...
heatman101
Sep 03, 2011 | Kenmore 24032\24036 Top Load Washer
Asko W6021 won't fill. It clicks and starts, but no water fills drum. I've cleaned drain trap but don't know how to clean inlet filter as suggested in manual.
The water inlet filters are inside where the hot and cold water supply hoses screw into the machine. Turn the water off, unscrew the hoses and they should be visible. However it might not be those causing the machine not to fill. If they needed cleaning the water would fill- but taking longer each wash.
If you confirm the filters are clear, it is more likely to be symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, or the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Asko W6021 Front Load Washer
Will not fill with water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Nov 27, 2010 | Zanussi ZT485 Built-in Dishwasher
Hi The white load program on my washer has just started to stop at 1 minute to go and appears to just continually cycle on the rinse stage. The coloured cycle works fine. Could you please advise?
Hi you dont mention make and model but I have come across certain brands Aeg Zanussi that wont unlock until the drum temperature is below 50deg c remaining on the last min until that happens. This can be caused by a blockage in the drain system ,pump.filter or hoses.this causes the wash water to be retained through to the end of the rinses. the higher temp of the white prog may be hot enough for the door unlocking to be delayed. A faulty door lock can also give the same effect(affected by the longer prog and temp). also check the inlet hoses if hot and cold are not the wrong way round. good luck
Nov 14, 2010 | Washing Machines
When start washing, filling water comes out from
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an F20 error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
Oct 11, 2009 | Zanussi ZWF1430W Front Load Washer
Special water hose needed?
i dont know of of a"special hose". are we talking about water inlet (hot and cold) hoses??drain hose??? or a vent hose for dryer???
1. stainless steel non-bursting fill hoses are available in up to 6' lentgh's
2. drain hose can be extended if need be, i would make it as short of an extension as needed, and use a hose of atleast the existing diameter and make sure that it wont, bent or pinch off after putting into drain pipe
3. dryer venting should be a solid aluminum 4" pipe as shosrt as possible with least amount of elbows needed.
all available at a quaitly home improvemnet store/ hardware store
Oct 30, 2008 | LG WM-2277HW Front Load Washer
Zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
