Hi, I have a kp53hs30 tv and a month ago, the image started "bouncing" up and down, both with the directv feed and with a dvd player. sometimes it bounces very fast and sometimes it goes all the way around like a vegas coin slot. It gets to the point where the top part of the image is seen at the bottom part of the screen, is there a quick fix for this? thanks!
  • eugarza Mar 22, 2011
    Thanks! Yes, I am interested to try a component level repair.. could you guide me?
    Thanks!
  • 4,889 Answers
I do not think there is an easy fix for this. The problem you have mentioned is associated with the V-hold circuits or the CRTs itself. So if you would like to try a component level repair then let me know and I will guide you
Posted on Mar 20, 2011
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
I have a Panasonic Quintrix F TV. About 6 weeks ago the tv screen started displaying
Rule out the signal source by seeing if same issue when a DVD etc is used.
Usually a wave like motion from bottom to top is either signal related or a problem in the power supply (wave moves from bottom to top suggests that).
If not on rear inputs (A/V) it is not the power supply.
Model number is not indicated here and might be helpful.
SD TECH
May 26, 2012 | Televison & Video
Hi I have a 32" UMC lcd tv/dvd and have sky plugged in through the scart. For the past 5weeks or so the tv flicks itself over to the dvd player mode on its own, when there is no dvd in the dvd player, and...
Hi, kitty_katzzz
Did you get a sensible solution for your TV problem? My 26" UMC tv/dvd combo has started doing the same thing (jumping to dvd player) a month ago. How have you cured it?
Sep 10, 2010 | Televison & Video
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Appears to be recording but is not. The player
Hi
Does your dishnet box have two tuners or one, if only one then only the program being watch on the tv can be recordered , this will have to be connected to the av input on the recorder and one of the av (line input) selected with the remote control for the recorder, If the dishnet box as two tuners then the output from one tuner can be used to feed the tv and the other one will go to the recorder connected through the av input. hope this will help regards windyhouse
May 11, 2010 | Toshiba DR410 DVD Recorder
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Problem with Lightning McQueen Tv/dvd combo
hi sir..
u told 9 monthly only. see whether it is in warrenty period.
Sep 02, 2008 | Disney DTD1363-CAR 13" TV/DVD
CODE FOR DIRECTV REMOTE
I am a installer for Directv and tv's that incorporate a dvd and/or vcr usually do not respond to the directv remote. Trust me I tried all the codes. I did find programming the av1 on the dtv remote for the dvd player would control the volume and on/off for the tv. Try the dvd codes rather than the tv codes. If no luck I recommend a Harmony remote which works well with combo tvs. Although expensive they are you must consider the convenience factor they provide.
Aug 27, 2008 | Toshiba 14DLV75 14 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
