Question about Epson Stylus Photo R1800 InkJet Printer
Epson Stylus R1800 refuses to accept art paper through the single sheet feeder at the rear When loading the paper the unit will pull it into the correct location and then on print command it backs the paper out and shows a paper jam message
    Sergeant:
  • 192 Answers
First check to see if there any any bits of paper stuck by checking the front and the rear feeder.
Also consult your manual to see if it accepts that thickness of paper.
It can be found here:
http://files.support.epson.com/pdf/r1800_/r1800_ug.pdf
The steps in the manual to clear a jam are on page 89 and types of accepted paper are on page 11.
Hope this helps.
Posted on Mar 20, 2011
Testimonial: "very prompt response...good advice"
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
80
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
20
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
There are black ink smudges on the bottom corners and edges of my color prints on velvet fine art paper. How can I stop that from happening. I already cleaned the heads twice. The prints are great...
The R2400 has an option to load paper on-top (Epson calls it the Automatic Document Feeder) and at the back. Based on the printer's User Guide the Velvet Fineart Paper should be loaded at the back. (Epson called is the Manual Single Sheet Feed).
Look at the User's Guide availabe on their website.
Jan 19, 2010 | Epson Stylus Photo R1800 InkJet Printer
My printer will not print card paper for xmas
Hi - I too am having an issue with my R1800 loading XMAS CARD STOCK paper.....I tried cleaning the rollers as per the EPSON web site. Although, I used alcohol in stead of water. I made sure I got the little roller way down under the paper and it seems better...although not 100%. Hope this helps!
Dec 02, 2009 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Can't select Velvet Fine Art media type when using sheet feeder as source.
I had the same problem, same printer. So with a little checking I found a solution. The paper has to be fed through the single page paper feeder. (See manual to setup. Can be downloaded from Epson.) Select manual/roll in the page setup section when you're ready to print. For instance, I was using 8.5 X 11 velvet, so select letter > then subset of roll/manual. After doing this velvet and other specialty paper profiles were selectable.
May 28, 2009 | Epson Stylus Photo R1900 InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper either just rolls through without printing or won't catch and sits there
This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
MDK
Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson R1800 refuses fine art papers
Hi Fruitless, Last night I was tearing my hair out trying to get my R1800 to accept some Hahnemuhle Satin 310, and it was just passing through and passing through. About once in 20 trys it would finally print. I was in the middle of making up my own paper profiles for this lovely paper. Anyway, I gave up at about 1:30 am, and went to bed. Today I resumed my attack, and guess what fella, there is a solution. Pass this on to everyone. You did not say what version of Photo Shop you were using. I just got my CS3 a week ago, and if you are using it, you can open a photo for printing. Go to Printing Preferences Dialog Box, > click on Maintenance Tab, and then click on the Bottom button that is labeled as Printer & Options Information. The Printer and Options Dialog Box opens, and there at the bottom is a box that says Thick Paper right beside it. Select or check this box and enjoy yourself thereafter. I did not see this in the User's Guide, but knew there had to be an answer to this problem somewhere. No problems ever since. Best of luck.
Sep 12, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
437 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
