Question about Garden
I have a coleman air compressor model 851-A2-80V1 I need to know what weight and type of oil should be used in this compressor
  • 604 Answers
Go to any hardware store and ask for "compressor oil" its all pretty much the same
Posted on Mar 22, 2011
What oil type do I need for an Ingersoll Rand type 30 model 253?
I've seen a lot of different oils used. I like IR's t-30 all season. use a compressor oil if at all possible. A 30 weight non-detergent is a minimum.
Aug 18, 2011 | Air Tools & Compressors
What type of oil do I use in model CPLDC 2541S
If you mean the CPLDC2541S (Porter Cable air compressor), you need to fill it with an air compressor oil. The recommended weight is SAE-30 (API GC/CD heavy duty motor oil). You can use a SAE-10 oil in harsh winter condiions. The manual is available from Manage My Life: http://www.managemylife.com/mmh/owner_manuals/20237/PORTER-CABLE-Air-compressor-L0309172 .
I hope this helps.
(note standard motor oils designed for cars are not appropriate for a compressor.)
Jun 21, 2011 | Porter Cable Garden
What weight of lubrication do i use for this compressor...Ingersoll Rand TS4N5? And do I need to bleed the tank off before adding oil?
Yes it is always a good practice to bleed the tank down. there is a check valve in the top of the receiver tank that keeps air from blowing back Thur the system. However if it's leaking you will have pressure on the oil sump. As for type of oil use a 30 weight non detergent oil. Recommend using ir's t30 all season or another type made for air compressor's.
May 23, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Coleman air compressor Model # MLO503013 what kind, type of oil is used in the compressor crankcase. The owners manual has been lost or misplaced. Thank you!
If it takes oil, you should use air compressor oil or, if you cannot find this product at your full service auto parts store, use SAE 30 non detergent.
Thanks for your visit today.
Dec 28, 2010 | Coleman Air Tools & Compressors
What type of oil does this unit take?
Air compressor oil. I prefer synthetic, but you can use regular compressor oil also.
Jun 26, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I CANT HAVE THE FACTORY OIL TYPE IN MY COUNTRY, CAN I USE ANOTHER TYPE? AND WHAT IS THE TECHNICAL NAME ? MY COMPRESSOR IS GA30 ATLAS COPCO TYPE.
Most air compressors will run fine using 30 weight non detergent oil.
You could drop the manufacturer a e-mail.
Your compressor shouldnt use a lot of oil ... maybe you are in need of some repair? New rings or bearings or seals?
Feb 23, 2010 | Air Tools & Compressors
I need to top up with oil, but do not have a manual to describe this
You did not list your specific make and model. However for most reciprocating type air compressors 1/2 to 8hp (without oil check window) you use the filling port as the level. The oil level is considered full when it reaches the bottom edge of the filling port. Just before it would begin to spill out. If it has a window then it will be full about halfway up.
As far as oil type there is oil specifically made for air compressors but just about any 30 weight will work.
Hope this helps
Oct 01, 2009 | Air Tools & Compressors
What type of oil for central pneumatic air compressor model number 94667
It should use 30 weight mineral oil, or 30 weight motor oil.
Aug 01, 2009 | Air Tools & Compressors
Type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Oct 30, 2008 | Ingersoll Rand Type 30 Reciprocating Air...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
