Hey guys I was starting up my car this morning and I noticed there is no air blowing out of my heater/vents to unfog the windows.. I tried turning it off and back on but still nothing is coming out. how can I fix this? it worked before..
  • prestigehack Mar 21, 2011
    No when I turn the heater on Nothing happens..
    Sergeant:
  • 259 Answers
Check the fuse to the heater motor.
Posted on Mar 20, 2011
Testimonial: "great Help :)"
  • 10 more comments
  • prestigehack Mar 20, 2011
    where is that fuse usually located?
  • Tim Venetis Mar 21, 2011
    It should be in the same area as the other fuses for your car.
    Just wondering would the level of coolant (anti-freeze).. could that be the issue??
    Your level of antifreze has a lot to do with it yes but when you turned the heater on did you hear the fan motor come on
    No when I turn the heater on nothing happens...
    either your heater motor is not getting current or the motor is burned out.
    if the motor is not getting any current is that like a circuit fix?? like it was working a few days ago, and for the motor are those usually expensive?
    Like it said i could be a bad fues causing motor to get no current and if it is a bad motor maybe you could buy a used one from a junk yard.
    we'll I checked the fuses today and the none of them are bad (all still connected none burnt looking)..
  • Tim Venetis Mar 22, 2011
    There might also be a fusable link in the wiring to the heater motor. Take a voltmeter and with the switch on see if you are getting current to the heater motor. not sure where the fusable link would be but if it is bad you could bend the wire easily in the bad spot.
  • prestigehack Mar 23, 2011
    Alright we'll today I took my jeep into my school shop and I took out the blower Motor and we tested it with a car battery and it does spin so it works..
    we tested the wire(plug) going to the blower motor and there is power running to it.. we replaced all the fuses and it still doesn't work.. Any other thoughts?
  • Tim Venetis Mar 23, 2011
    If you are getting power to the motor it should work. With the motor out plug it in to the wire connection and see if it spins. If there is a ground wire make sure that is clean.
My evaporator light keep flashing
Posted on Mar 22, 2011
Air condition
What's Wrong With My Car's Heater? - Popular Mechanics
www.popularmechanics.com/cars/.../whats-wrong-with-my-cars-heater-1...
... hot air you need. Here's what to do if your vehicle is struggling to turn up the heat.... In the recently chilly mornings I've noticed my heater isn't putting out hot air. ...Surely it's not saying it won't play the DVD because 1 doesn't match Free. And, yes, it.... The Nurburgring Nordschleife should need no introduction. Nearly 13 ...
How to Fix a Car with No Heat (Easy) - YouTube
? 10:56
https://www.youtube.com/watch?v=-XjXTVJhFLM
Nov 21, 2014 - Uploaded by ChrisFix
Car not blowing hot air? This video will show you how to fix yourcar's heater whether it is your heater ...
Car Heater Not Working - Troubleshooting Repair Tips ...
? 4:05
https://www.youtube.com/watch?v=aCkVjiPZA4o
Oct 1, 2013 - Uploaded by WiseAutoTools
When troubleshooting to try and repair the car heater, check the coolant ... If a cooling system is full and there's still no hot air coming from the vents, .... Hi I have 2001 ford expedition and theheater just blows out cold air and ...
Dec 29, 2015 | Cars & Trucks
Heat problem. Heater only works sometimes. Blows out almost AC temperature majority of the time. No engine overheating problems. May or may not be related to actuator issue (vent always open)
Check to see if your heating system is properly filled. Air in system can often prevent the proper flow of hot coolant into the radiator core resulting in your issue.
Oct 20, 2015 | 2002 Chevrolet S-10
Coolant leaks heavily from passengers side. Started yesterday morning on the way to work. I noticed the vents weren't blowing hot air. Then I noticed the car start to overheat. I didn't drive any more...
Ok, may i suggest that you check your HEATER COIL, you can located it by pulling up " HEATER COIL" for your specific vehicle, this is what your coolant travels thru while hot and air passes thru this coil to produce the heat to warm your vehicle and typically the heater coils are located on the passenger side. Now as far as the leak location, check heater coil connections it could be the coil itself. GOOD LUCK!
Nov 26, 2013 | 2002 Chevrolet Malibu
95 honda passport heater does not work. Fan turns on but no heat. No clue what it could be. I noticed the problem after I had a radio installed and the automatic transmission rebuilt.
May be in the radio installation. I hate pointing fingers at the last guy who worked on stuff, but they could have hit a blend door.
When car is warmed up, turn heat on vent and like 3/4 power for fan. Turn temp knob from hot to cold. You are looking for a temperature change. Now, turn on a/c to vent. Wait for it to blow cold. Turn temp knob to hot. Looking for air to be warmer that it was. POST RESULTS
Nov 22, 2013 | Cars & Trucks
1988 chevy sprint Heater defrost and floor heater works but face heater blows out cold air
this cars are not suppose to blow hot air to the face vents ,if you notice there is a blue arrow on the selector for face air
Dec 11, 2012 | Cars & Trucks
I have a 93 4runner v6 manual. I went to turn the heater on the other day and no air was coming out of it but when I started driving down the freeway air started coming through the vents. When I stop
sounds like your fan is either jamned, burnt out or even frozen, you might be lucky and find its just a blown fuse, you'll need to check your fuses box then start investigating if the fan turns freely or not
if you put the air on recirc you might be able to stop cold air blowing in when you are travelling. if you are waiting for a garage to sort out the fault then get a fan powered by the cigarette lighter, air moving over the window should at least keep mist clear even if it doesnt defrost it
Nov 09, 2011 | 1993 Toyota 4Runner
I noticed air was not blowing as hard as it should out of the vents,and when i had the hood up air was blowing out of the cowl vents,where should i start?
check the cables that control the flaps inside the heater housing. they can pop off sometimes and cause this issue.
Dec 23, 2010 | 1995 Oldsmobile Eighty Eight
Heater steams up all glass on inside of car
pop the bonnet(hood) right under the windscreen rubbers you will see a blavck plastic box about 3feet wide,clean out the drain under the fan unit,it is blocked with s...
Apr 26, 2010 | 1992 Audi 100
Heater blows cold air from top vents after running for 1.3 hours
Sounds like you may be able to fix it by flushing your antifreeze and back flushing the heater core. Some car owners cheep out and put stop leak into the antifreeze, others dont change there antifreeze at all. Both are mistakes.
Mar 05, 2009 | 1990 Chevrolet Lumina
My a/c fan or another fan that I don't know will not stop blowing. I turn off my ac unit. I turn off my heater. I even shut off my car it keeps blowing. I had to unhook my battery to get it to stop. ...
I HAD THE SAME PROBLEM IN ANOTHER BUICK . IT WAS THE COMAND MODUEL BEHIND THE GLOVE COMPARTMENT, THE SPRINGS THAT OPEN AND CLOSE AIR FLOW WINDOWS
THAT RUN FROM THE UNIT WON'T CHANGE FROM HEAT TO AIR TO YOUR VENTS.YOU NEED A NEW COMAND MODUEL OR HAVE IT REBUILT . IT OPENS AND CLOSES THE VENT DOORS . I GOT MINE REBUILT FOR $50.00 FROM A GUY THAT WORKED AIRCON LINE @GM
GARAGE QUOTED ME $650.00 HOPE THIS HELPS.
GOOD LUCK
Jul 27, 2008 | 1997 Buick LeSabre
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
