Question about Hotpoint Washing Machines
I have a hotpoint wd420p washer dryer and its stopped mid cycle. its full of water and i need to know whats wrong
To fix the problem I stripped down the pump and discovered it was jammed with a hair clip!!
Posted on Aug 04, 2008
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Aquarius WD420P has something stuck in its output hose
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Stopped mid cycle with the code F 05 flashing up, it has been tried since with the same thing happening. Not sure what the code means?
F05 means pressure switch jammed on full.
You need to locate and clean pump filter, if not at bottom front of washer, then remove lower rear panel, remove large black hose on bottom of drum, remove and clean filter inside hose.
Fit back and test.
Mar 02, 2010 | Hotpoint Aquarius WD640 Front Load...
My hotpoint WD640G has stopped mid cycale and is showing the code? F O5 and will not complete the cycle
Error code F05 denotes pressure switch jammed on full.
Remove the lower rear panel of washer.
Remove the large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Feb 06, 2010 | Hotpoint Aquarius WD640 Front Load...
What kind of motor installed in hotpoint washer/dryer model No. WD420P
It is a brush type motor, rated at 1400rpm.
Runs on mains 240v
Trust this is the info you require.
If you need more info, e-mail me.
Thanks.
Dec 06, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
My hotpoint washer is stopping mid cycle if i dont pump the water out it floods it will only work on thr h cycle
I WOULD HAVE THE PRESSURE SWITCH CHANGED OR CHECK THE SMALL TUBE GOING FROM THE PRESSURE SWITCH TO THE DRUM AS IT MAY BE CHOKE WITH WASHING POWER AT THE DRUM
Jul 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wf860
not sure about the f04 code but if its still full of water try putting the washer onto a drain cycle if the water does not drain then your pump is either blocked or faulty to check if its faulty pull the washer outnow take the drain hose and place into a bucket low to the floor if it comes straight out then the pump is faulty what it is is they have a magnectic part which goes down if the water doesnt come out its blocked you will have to take the washer outside tip it backwards but dont put it on its back now undue the sump hose which is situated in the centre of the drum pull it the water will drain out now undue the 2screws under the pump pull out undue the pipes you should see the blockedge if not could be in the drain hose itself m8 let me know how you go on if the pump needs replacing shouldnt cost no more than £20
Nov 16, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
