SOURCE: Oven racks don't fit anymore.
This is very strange... I know the racks in our oven ONLY fit one way and it is NOT obvious which way is right. We have taken them out and found they would not go in and we finally turned them over and end for end and they work. It is hard to remember how these things go in as it is not something we do everyday. Try upside down and end for end... It is UNLIKELY they have deformed or that the cavity has changed shape or size.
SOURCE: Kenmore model 36275575691 oven rack is
GO TO A CATERING OUTLET AND ASK FOR OVEN RACKS ; ALSO CONTACK SUPPLIER TO SEE HAVE THEY ANY IN STOCK.
Hi
Error
code F1 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
