Question about HP EliteBook 2530p Notebook
Hi mr hp i have a hp elitebook 2530p when i removed the battery i noticed i have a sim slot when i looked closer can even see the gold sim contacts. Yet i slot my sim in and get no response. In device manager i have all my driver s except one. I downloaded connection manager and the gobi staff which they say should install the drivers . Wat i wanna know is do i even have an integrated modem in this model that i do have? If you would like to know any more info let me know . Thanks
The easiest way to determine if the 2420 module is installed is to open the mobile broadband module trapdoor on the underside of the notebook. This is the small door near the battery bay, you should see a wireless icon on the door with an arrow pointing to the single screw that secures the trapdoor. If there is no 3G module installed the slot will be empty and you will find two antenna connectors taped down. There is an upgrade kit available for EliteBooks if you are interested in adding this feature.
Please note, there is a larger access panel with both a wireless and memory icon (thisis the wifi card.)
-Former HP Mobile Broadband team member (laid off when the group was sacked after launch, but proud of our product.)
Posted on May 14, 2011
How to use SIM in HP elitebook 8440?
That's for Ray Gallant who thinks there's no sim card slot in a lapotp :) . It is a 3g modem build in .
About your question you will need to download drivers from
HP EliteBook 8440p Notebook PC
here for the modem . You will need to select your operation system then go to Software - Solutions > and download HP Connection Manager . If it still does not work you may try to download some of the Driver - Network drivers but i'm not sure which one will work.
Mar 27, 2015 | HEWLETT-PACKARD HP EliteBook 8440P...
SIM card help on HP elitebook 8440p
That's an SD memory card slot, not a SIM card slot.
Mar 30, 2014 | HEWLETT-PACKARD HP EliteBook 8440p...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
HP Elitebook 2530p switches on but no display
Hello!
Just a quick one or two at the moment. Have to locate the problem then figure the fix sooooo..
1. Please refer to the photo: Note the 'hands', one at the top right and the other at the bottom right of the screen. With the power on and the computer in the normal ready to use mode....
What I suggest you do is hold the bottom right corner firmly, keeping it relatively immovable while, at the same time, GENTLY, and NOT completely, SLOWLY start bringing the top left corner down toward the bottom right corner, actually moving the top barely an eighth of an inch, flexing just a tiny bit...
If the display flickers then, hopefully, it is a loose display cable, usually a flat one that lies under the keyboard and need only be adjusted. a tedious but very inexpensive solution.
Another quick, albeit unlikely fault to check is your battery. I know, I know, it's so obvious but I have to ask: Have you tried using the computer from a DIFFERENT wall outlet, better still, at a buds house?
Let's get these two out of the way before moving on? Let me know! I'll look into recalls, frequent problems, etc....
Jimm
Nov 21, 2012 | HP EliteBook 2530p Notebook
Hewlett Packard EliteBook 2530p Memory Upgrade
The 666 in the part number indicates a 666 MHz memory stick. In the spec of the HP 2530 P, it needs DDR2 800 Mhz memory. Possible that the memory is not compatible.
Dec 29, 2011 | HEWLETT-PACKARD ELITEBOOK 2530P BUSINESS...
Hi my hp elitebook 2530p wont boot up.when i turn on one light comes and stay.but wont boot up.even i can not hear fan noice.thaks
one possible cause would be the hardware problem, better to send it to the technical person inorder to prevent further damage of your laptop. Just a suggestion thanks.
Sep 22, 2011 | HP EliteBook 2530p Notebook
Dear, how to reset bios hp elitebook 2530p?
Dear untung widi,
Welcome, and thank you for using FixYa!
You will have to remove the Power cord, battery, and keyboard. The screws for the keyboard are on the bottom.
You should then be able to see the BIOS battery and remove it. It will have to be removed for at leat 10 minutes to get the system to do a full reset.
If your issue is the password locked into the BIOS, this is a known issue with this model. Follow the instructions at the link I am providing to assist you.
BIOS password reset help
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01798858&dimid=1137549722&dicid=alr_jul09&jumpid=em_alerts/us/jul09/all/xbu/emailsubid/mrm/mcc/loc/rbu_category/alerts
Have a great day!
Sep 11, 2011 | HP EliteBook 2530p Notebook
HP Elitebook 2530p won't start, power thunderbolt light flashing
had the same problem - press and hold th power button without the battery connected for 30sec
refit battery and try again - it worked for me
Aug 02, 2011 | Miscellaneous
HP Elitebook 2530p power lights stays on after
are you switching off, or just closing the lid? On most laptops, closing the lid just hibernates and constantly uses power, it can be changed in the control panel power options.
Mar 26, 2010 | HP EliteBook 2530p Notebook
HP EliteBook 2530p Notebook Logo
578 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
