Question about HP Blackbird 002 BB5140rp Core 2 Quad Q9450 4GB DDR2 500GB Dual NVIDIA GeForce... PC Desktop
Wont start up...fans jolt momentarily then nothing no blue screen,no hp screen nothing on my monitor. Computer just sits idle I can see a blue light on the board thats on and when i push the button to start a yellow one comes on but nothing. i strongly suspect the power supply has issues
  • 1,179 Answers
Sounds to me like your computer system is in short circuit protection mode.
The PC is off, then when turned on it jolts on and quickly off again.
See my published guide to solve this problem, they are listed below:
How to Remove the Side Panels of My Computer Chassis!!!
How do I reset my BIOS/CMOS to defaults?
My Computer is not turning on!!! Is it dead!!! No POST!!!
It problem may be due to moist dust which is causing a short in the circuit.
The problem may be solved by opening it up and cleaning out the dust, letting it air a bit to dry.
You may want to consider warranty support!
Thumbs up!
Thanking you
damnor01
Posted on Mar 20, 2011
Hp Desktop wont turn on
You have to restore OS to original factory status. May be pressing F10, F2, F11 or F12 while PC is starting, then follow instructions on screen.
Jul 04, 2013 | Computers & Internet
My compaq fs7600 monitor wont turn on
Hook a spare monitor to the computer, if no change! the Video Graphics Card is suspect usually built into the motherboard. But if spare shows picture, the problem lies in the HP monitor, as a last resort change the video cord from the computer to the monitor "if possible" to rule out something simple.
Mar 15, 2012 | HP Compaq FS7600 17" CRT Monitor
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Slow flashing blue power lite. Monitor shows no
First when you power up the computer press F8 key then enter in enable vga mode.
If you are able to enter then go to start menu->control panel->display property ->settings.
Change screen resolution to 1024*768 then apply and ok.
But if you are not able to see safe mode and other menu.
Then open cpu cabinet .
Refix RAM memory.
Pull cmos cell from motherboard for 10 minutes.
Reattach all connection harddrive.
Open processor fan and processor remove dust from all parts.
Make sure motherboard is not ground with cabinet.
Remove PCI cards if any.
After all above still same then change RAM then try.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 19, 2009 | Gateway DX4640-UBC01A PC Desktop
I have an hp Zd7000 that wont start i can hear it trying to.
Did you try the FN+screen switch key. maybe check to see if nothing is loose ( hdd, ram ) also the bios to see if screen settings are correct
Oct 01, 2009 | HP Pavilion zd7010us PC Notebook
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Blank/Black Laptop screen on HP DV-6000 notebook
Please have a look at this article and consider updating the BIOS: click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 03, 2009 | HP Pavilion dv6000t Notebook
Can't reset computer for HP 24" W LCD
I would suggest try rebooting in SAFE MODE and the right clicking with the mouse on the screen go to properties then setting and change the area of the screen
Jan 22, 2009 | Computers & Internet
HP Blackbird 002 BB5140rp Core 2 Quad Q9450 4GB DDR2 500GB Dual NVIDIA GeForce... PC Desktop Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
