Question about Air Tools & Compressors
Kobalt 1.3 22 gal run for a second kicks off for about a minute then repeats will not continue to run
5 Suggested Answers
ollie reece
  • 1167 Answers
SOURCE: kobalt air compressor won't run
hi mate take the head off and inspect the valves and gaskets i had this problem and it was the gaskets gone just make sure the valves are opening and closing ok good luck
Posted on Aug 08, 2009
  • 10 Answers
SOURCE: Kobalt 26 Gal Upright keep tripping the reset
An few pointers that might help.
- If you are using an extension cord, try plugging it directly into the wall.
- If there is any type of arching from the motor area, then most likely there is motor damage.
Posted on Oct 31, 2009
compman66
  • 169 Answers
SOURCE: problems with kobalt air compressor 26 gal. simply
Check and reset motor thermal overload (red button) on motor, also check circuit breaker for your power supply. other than that the pressure switch is what stars and stops the motor, and depending on your level of knowledge you will need to check continuity through the pressure switch with a ohm meter.
Posted on Jan 20, 2010
Testimonial: "Thank you for your reply. I'll check it the morning........"
SOURCE: HOW TO WIRE A KOBALT 60 GAL VERTICAL 208-240 TO
i have a KOBALT 60 GAL VERTICAL 208-240 wired up like it should will not start or nothing
Posted on Feb 23, 2010
Compressor only stays running for about 10 seconds and kicks off. Will not turn on for about 3 minutes and continuously repeats this cycle.
Sounds like the compressor has siezed. Switch off to cool for 3 h.ours and try to restart. If it has a start capacitor, repace it
Jul 14, 2015 | Refrigerators
Screwed wingnut the wrong direction when trying to drain 60 gal. Kobalt compressor....can it be put back on?
call lowes there might b a service to get it fixed sound like u broke something to me get help
Apr 21, 2012 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I have a 25 gal. craftsman oilless air compressor. Runs for about 1/2 a minute & than kicks the breaker out.
Hello babeaton, several things can cause that, but, the most common thing is the regulator. let it run again and right ofter it kicks off feel the power cord and see if it's warm to the touch, if so it likely is the regulator. Breakers operate based on the amount of heat generated from current running through the cord/wires.
Good luck my friend!
Jan 16, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
HOW TO WIRE A KOBALT 60 GAL VERTICAL 208-240 TO BREAKER PANEL
Feb 09, 2010 | Air Tools & Compressors
Problems with kobalt air compressor 26 gal. simply would not start
Jan 20, 2010 | Air Tools & Compressors
Kobalt 26 Gal Upright keep tripping the reset button. Won't stay running more than a couple of minutes
Oct 31, 2009 | Air Tools & Compressors
Kobalt air compressor won't run
Jul 23, 2009 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Algebra
59.88 MINUTES.
Example assume tub is 10 gallons.
10 minutes to fill is 1 gal/minute
10 gallons drain in 12 minutes =10/12=.833 Gal/Minute.
1 Gal/Min - .833 gal/min= .167 gal/min gain in water/min.
10 Gal/.167=59.88 minutes.
Apr 21, 2008 | SoftMath Algebrator - Algebra Homework...
Air Tools & Compressors Logo
138 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
