Question about Toshiba 32AF45 32" TV
Tv goes off by itself every few minutes - Toshiba 32AF45 32" TV
  • Toshiba Master
  • 1,229 Answers
You have bad solder grounds in your TV. There will also be some bad capacitors. Look for capacitors in the range of 160 volts to 250 volts at 1Mf to 2.2, 3.3, or 4.7Mfs that are bad now. Another common capacitor that goes down are the 25 volt or 35 volt 100Mf ones. The next area would be your vertical IC , it will need resoldered. This is true any most cases of any brand. The capacitors next to the vertical IC will need checked and replaced. A bad cap here will heat the vertical IC and separate the pins from the board. Last and be sure to do this. Check the small board connected to the picture tube. By now this board (CRT) will have many bad grounds. Heat is the enemy of any television. Hope I could clue you in to a repair. Thanks for asking and show a few hands of support!
Posted on Mar 20, 2011
Turn on, comes green led then goes off after few minutes.
Does the whole TV go off or just the lamp? If it's just the lamp, the ballast board which is directly connected by wires to the bulb is going bad. If the whole TV goes off, then something is dragging the power supply down or the power supply board itself can be bad.
Jun 19, 2015 | Televison & Video
My Panasonic LED TV picture goes away after a few minutes
Could be a bad connection that disconnects when heat in the system causes it to expand. Take to a pro or call manufacturer, they might have a recall or free repair available.
Apr 03, 2015 | Panasonic TC55LE54 55" 1080p 120Hz SMART...
LG 42LC7D-UB after few minutes the sound goes off and channel change by itself
When heats up, the supply voltage from the main power supply board goes less. Check all the soldering to this board for any loose solder terminals. Resolder all the suspected solder terminals by applying a little more solder. If it do not help you, replace the board as card basis.
Jan 09, 2013 | LG 42LC7D-UB Television
Tv goes blank after a few minutes. Turn tv off and back on and it will come back on for a few minutes and go blank again
You are having trouble with a thermal protection switch in the TV. The power supply will have to be replaced. It is also possible that your lamp (tubes behind the LCD panel) are going bad and drawing too much current and causing the power supply to protect itself.
-Mark
May 06, 2011 | Insignia 42" LCD Flat-Panel HDTV
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from www.tvrepairworld.com
Jul 16, 2010 | RCA HD52W66 Projection Television
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 32AF45 32" TV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
