Question about Hitachi 55HDS69 55 in. Plasma Television
I cajnt get closed caption to work. My audio and video input to the tv are HDMI only
  • 902 Answers
Did you try turning on cc from your cable box?
Posted on Mar 20, 2011
How do I turn off closed captioning in HDMI? I've turned it off in tv mode but it still is on. It's annoying
What's the HDMI source? You need to disable the CC on the cable box or DVD player. These are only two of the possible HDMI sources that will provide the captions directly.
Without knowing the source, I can't tell you how to disable the captions. For many devices, you'll need to enter the settings. (Some cable/IPTV boxes will need a passcode to enter the settings menu.) On my IPTV box, the CC option is tucked into the Hardware Settings under Audio. On some satellite TV boxes, I found that the closed captioning had to be turned on at the primary box and that would enable secondary boxes to also show the captions. (It was an annoying feature for a family with one hard-of-hearing guest. They didn't need closed captions on the primary box. The specifics of their set-up and service meant that the secondary box couldn't display captions directly.)
Please add a comment with the HDMI source for specific information on turning off the captions that you currently see on that source device.
Nov 27, 2017 | Televison & Video
Above pretty much says it. The "Caption" function under "Option" is greyed out. Can someone tell me how to "ungrey/activate the closed caption option?
If the closed caption is shaded out in the menu, this usually means closed caption is not an option. Closed caption can not be turned on if the TV is on component, RGB, DVI, Or HDMI inputs. The closed caption will need to be turned on by using the set-top box or other device that is connected to TV inputs. or if the tv is connected directly to the cable line or anteanna
Dec 03, 2010 | LG 37LP1D 37 in. LCD Television
I am connecting a RCA DVD player (DRC277B) to my TV and have problems when using the HDMI cable. When I connect the unit using the AV Cable, things work OK. I then turned off everything and hooked...
Hi
Thanks for using FixYa. Two things that will cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the not available message. I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts
Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 15, 2010 | RCA Televison & Video
I have a pioneer VSX-1019AH-k receiver connected to a Samsung LED tv via HDMI. I am trying to use Closed Caption, but when I click on CC on the TV remote it says Not Available. Any help getting CC to work?
close captioning on a tv is usually only available for use when the antenna inputs are being used. it has no way to process a cc from an auxiliary source. you should have the capability of cc with a menu item in the cable or satellite box and with the subtitle command in your dvd. good luck
Feb 10, 2010 | Pioneer VSX-1019AHK A/V receiver
No signal from coax input on 32" lcd
Hi
Thanks for using FixYa. Due to two things that will cause the No Signal message to come up are – no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No Signal!
If this doesn’t resolve your issue then the problem may be with the processor failing and it is causing a random read of the EPROM to display the No Signal message.
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts.
Try using Component cables if this doesn’t make a difference. After using components cables your issue will be resolved.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 16, 2009 | Insignia IS-LCDTV32 32 in. Television
Close captioning on HDMI
The TV will not display closed caption with HDMI input. It must either over-the-air (antenna) or composite input for the TV to manage CC.
To get CC with HDMI from your Comcast DVR, you need to configure the cable box. Instructions can be found here:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR/Setup
If you want CC all of the time, this works well. But since you must power-off the cable box to change the setting, switching CC on and off is a real pain.
Your set-up is similar to mine (Sharp Aquos 46" and Comcast DVR). I have the composite output from the cable box going to a DVD-recorder and on to the TV. Whenever I need CC (usually to catch some mumbled dialog), I just rewind the DVR, and switch the TV input to the composite input. Then I switch back to HDMI to continue watching in HD.
Mar 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I know which converter box to buy?
here are the specs for the Magnavox TB100MW9
Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
Jan 04, 2009 | Televison & Video
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Close caption works when I select the input for tv, select hdmi input and the close caption option disappears from the menu. I have a shaw cable pvr hd box and need the close caption to work on all...
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
Jan 12, 2008 | Dell W4201C 42 in. Plasma HDTV
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
Hitachi 55HDS69 55 in. Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
