Question about Char-Broil CharBroil Master Flame Gas Barbecue Grill
First burner ignites quickly, second and third take up to 3 minutes IF they fire at all. burners are not clogged.
    Brigadier General:
  • 4,736 Answers
If the first burner's flame characteristic's look right, the remaining burners need to be removed and the venturi valves and burner orifices checked for obstructions and cleaned if necessary.That's generally the cause of delay ignition.
Hope this helped and Happy Grilling!
Posted on Mar 20, 2011
Burners slow to light
clogged fuel lines
Mar 18, 2014 | DCS Cooktops
Thermador over two left burners will not provide gas when knobs are turned. Also the oven will not light and the igniters on all burners will not spark. The electric is good to the appliance oven fan
You have multiple problems! First the single igniter that fires in all of the burners is either broken or disconnected electrically. Second, your gas lines or nozels at some of the burners are clogged. Check for cloggs by using a match as you light ONE BURNER AT A TIME...If they all light you only have the electronic igniter to troubleshoot...Have a repairman check it out for you if you don't feel confident with gas!
Dec 21, 2012 | Kitchen Ranges
The self ignighter does not work only for 1 burner
I have a Weber and the igniter only works for the first burner.
The second burner ignites off the first burner.
The third burner ignites off the second.
Gary
Jul 16, 2011 | Garden
Just got the bbq yesterday - the 2 burners on the left ignite and burn normally. The third burner on the right won't ignite either manually or with igniter...you can hardly hear the gas coming out.
It may be a case, that the burner orifice for that burner is clogged with shipping debris or something similar. Remove the third burner and inspect the orifice for foreign debris. Also, check the venturi valve on the end of the burner for clogs. Onward Manufacturing, the company that makes Broil King grills is a good company and stands by their product. If you continue to have a problem with the grill contact their Customer Support Hot-line 800-265-2150.
Hope this helps you to troubleshoot and solve the problem. Please let me know and Happy Grilling
May 23, 2011 | BroilKing Signet 20 Gas Grill
Shortly after igniting the infrared burner, and while the burner is still heating up, the gas will explode spontaneously, blowing out the flame.
What you have is partially delayed ignition, This could be caused by a manufacturer's defect or the burner is clogged with debris. To test this theory, when you're preheating the burner, preheat on the lowest flame setting that you have, that will keep the burner lit. After 8 to 10 minutes, gradually turn the flame up to high. If the burner responds as it should, you shouldn't get that delayed ignition problem. If you do get it, the burner is defective and should be replaced.
Hope this helps solve your problem.
Feb 28, 2011 | Fire Magic Infrared Burner System For...
Hello, I have a Amana Air Command 80 model #GHI90A50, 22 years old. This furnace is on its third ingnition module (last one two yeras ago). The symptom I am trying to diagnose has been ongioing since this...
If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Dec 05, 2010 | Heating & Cooling
Have Whirlpool Model # LGB6200PQO dryer runs but does nut dry. Burner kicks on with fire on gas dryer but after about 5 min kicks off after a few minutes the igniter glows on but no fire then kicks off...
The moister sensor can be bad or good. If the exhaust tubes are clogged with any lint build upo the sensor is working putting the burner into check
Jul 28, 2010 | Whirlpool Dryers
Own a charmglow gas grill 3 burner, having trouble igniting burners will not ignite, how do you match start
I have used those long-necked lighters as a temporary thing. You can buy replacement igniter kits at Lowe's/HomeDepot/similar, and they are easy to use. I hate to admit it, but I have taken the igniter out of the side burner that is attached to the grill and used it, until I bought a replaement. Match starting is a less than favorable option, as you are putting your hands and face in a bad place, but if you just have to do it, remove the grill grate over the burner that you intend to light. Get your fire source to the burner, and turn the gas on low. If the burner doesn't light pretty quickly, remove the fire source,shut off tha gas and wait several minutes with the lid still up for the gas to dissipate. You don't want to be trying to light the grill and have it flash on you. Most grills have an opening at the rear if the grill for manual lighting. Even so, the long lighters are waaaaaay better than the old kitchen match. I'm sure that you know, but always have the lid open when lighting the grill. (I just had to say it!)
Hope that this helps...really!
Best regards, --W/D-- please feel free to rete this solution! Thanx!
Jul 29, 2009 | Grilling
Problem with gas getting to the front burner
Follow manufacturer's recommendation in resetting the excess flow safety device....(Turn burners and LP cylinder off...Disconnect regulator on cylinder. Turn both knobs to high for at least one minute...Then turn them to off...reconnect the regulator to the LP tank...Turn LP valve VERY slowly (30 seconds) until fully opened..then start the grill in the usual manner. ALWAYS TURN THE LP TANK OFF WHEN DONE USING THE GRILL....
Jul 04, 2009 | Weber Genesis Silver B Grill
Grilling Logo
169 people viewed this question
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
