Question about Pentair 1.0 Hp Whisperflo Pump
Pentair pump won't start, doesn't hum or anything. when i press the pump button, the control panel makes a little click nouse and that is it.
    President:
  • Pentair Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Use a meter to measure voltage at the motor terminals...If the unit is getting power the trouble lies within the motor; if not look at the controls. The click should be the relay for the motor closing. If you do not have power to the motor you will want to start with that relay; check for incoming and outgoing voltage. I imagine that if there is no power to the motor you will find the relay is bad. The click suggests the low voltage side is working and the relay is trying to close but if the primary is burned up no power will get to the motor.
If the motor is getting power you'll probably want to pull it and take it to a local electric motor repair shop. They should be able to identify what failed and offer a repair quote if the motor can be salvaged.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowmotor.net. Positive feedback is appreciated once your problem is solved!
Posted on Mar 22, 2011
I have an Pentair Easy Touch 8. I push the Filter button on the outdoor panel. The green light is on but my filter does not turn or start on. I ran the Self Test and no error code. Any idea's?
this could be a number of issues....
Pump motor could be bad, capacitor could be bad, relay could be bad, or a circuit board issue.
Check the breaker for the filter pump, turn it off and back on.
Press the reset. It tim on the outdoor control panel and wait for a few minutes as it reconfigures.
Then try to turn it on again.
If that doesn't work
If you know how then test the leads at the motor once you have pressed the filter button.
Otherwise you probably need a professional to check on it.
Dec 31, 2016 | Pentair Pool & Spa
Crosley washer won't agitate
Hello Carroll Mcknight - Is the washer making a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned. If not, the unit may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Contact a professional to assist with the repairs and to move forward accurately.
Jan 22, 2013 | Washing Machines
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
Detergent door won't close, dishwasher won't start
Contact a professional technician to see if the spray loaded action needs to be replaced with a new cup area.
Aug 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
Pinnacle high performance one hp have a reset button
if humming and not running bad start up capacitor or bad motor replace pump be safe
Apr 20, 2012 | Pentair 1HP Pinnacle High Performance...
"p' button on my pentaire
If the "p" button has been used very frequently it may have worn out. If you are into electronics at the component level. technically you might be able to verify this hypothesis and if defective. buy another switch (this may be hard), and solder it in. Unfortunately the manufacture doesn't recommend this (they don't get to sell another one) and it is easy to cause another problem when you work on the board. The problem could instead be something that would be much harder to diagnose and nearly impossible to repair outside of the factory or development lab.
I hope this helps.
Sep 05, 2011 | Pentair Easy Touch Indoor Control Panel...
On light does not glow and can not "stop" the system
the rain shouldn't have hurt the control panel. it sound more like damage due to lightning.
Jun 07, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Pentair 1.0 Hp Whisperflo Pump Logo
517 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
