Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby belt attachment
My Kirby Sentria powers on, but the brush head is not spinning. How do you attach the belt so it works properly?
Try this link, Its all about how to fix your problem.
http://www.greatvacs.com/Kirby%20Brushroll.shtml
Posted on Aug 11, 2008
Kirby sentria 2
Make sure the belt is the right size.. It should be very very tight.
Apr 16, 2014 | Vacuums
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
Hi -- I have a Kirby Sentria and it is great except that I am getting no suction at all through the big silver power head. Suction through all the other attachments works well. I haev tried it with the...
You can take off the power head and look in that whole where the belt is and see if there is a paper towel or something in there clogging it up.
Also tug on the belt and make sure it is tight - because if it is loose it is broken and you need a new belt.
While you have the head off, put on your hose attachment and use it to **** out any debris stufk in there.
Dec 08, 2009 | Kirby Vacuums
Kirby sentria
remove the cloth bag from the bottom it twists counter clockwise, un clip the bag from the top remove the head piece, turn the belt lifter clockwise and release the lever to remove the head, take off the head, in your attachments there should be a screen that covers the impeller that the belt rides on it goes on like the brush head, put your hose onto the bag port by turning clockwise. there it is it will not work without the screen cover. thanks Rene
Aug 29, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby Sentria doesn't pick up visible dirt
As far as picking up - I suspect that your belt is not properly installed. Watch the video manual HERE. in the first halve of the video there is an instruction how to properly instal nozzle.
You have to turn the bag about 30-40 degrees countercloclwise so plastic protrusions on the tube top adater (ones that keep bag attached to the tube) will allign with cuts in bag cardbort so you can pull the bag off the adapter. If you will take a look at the new bag - you will see what I am talking about.
Dec 08, 2008 | Kirby G6 Bagged Upright Vacuum
I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G will not suck with main brush head attachment
You may need a new belt, it may have stretched enough so it isn't turning the brush roll anymore.
Mar 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Sentria - Not distributing shampoo correctly
this site may be helpful
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
make sure the brushes on the shampooer head are spinning and that you have the shampooer head lowered all the way down to its lowest setting. Also...shampoo at a slower pace than you would move when vacuuming...when both putting down the suds on heavily soiled areas and scooping them up. The more oils in the carpet, the less suds you'll see when the shampooer is working properly. one more thing that may be mentioned in the guide is the little round sud screen that attaches to one end of the shampooer hose...make sure that little mesh screen is there and seated properly. It is what produces the suds from the shampoo solution.
Dec 07, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
301 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
