Question about Skil Saws
Skilsaw 5155 stopped working not hot - Skil Saws
    Sergeant:
  • 259 Answers
Check the switch with a ome meter
Posted on Mar 20, 2011
Where is the blade lock on the skilsaw 5155
Hi Emory:
Your question made me think................
None of the skil saws that I have owned, or still have, came with a blade lock. Maybe yours has one, but if I needed to pin the blade while undoing the bolt, I'd do like I always did......... Unplug the saw....... and slip a carpenters pencil between the teeth and rotate the blade until the pencil came up against the deck.
There is also usually a hole in the blade, and a nail slipped through the hole makes a perfect blade lock.
Oct 03, 2015 | Saws
Cannot complete remove the motherboard,
See the link
http://www.bing.com/videos/search?q=youtube+HP+Omni+100-5155+disassembly&FORM=VIRE5#view=detail&mid=3D3F3E1E8F8F55DDF69F3D3F3E1E8F8F55DDF69F
Don't forget, you need to have this all on one line if you cut and paste the link.
If neither works, I just used www.Bing.com with the search of
youtube HP Omni 100-5155 disassembly
Good Luck and Make it a great day!
Nov 22, 2013 | HP Omni 100-5155 AIO Desktop PC C-Grade
Skilsaw 5150 7 1/4'' stopped working, I think it overheated?
Yes, it overheated. Not worth fixing, replace it. What happens is that with a very heavy load the saw tries to run a lot of current through the little coil wires that are only insulated with varnish. They heat up, the varnish melts, and a few of them short out together, which increases the current further, causing more heat and more melting until enough shorting in the coils that it won't do anything except trip a breaker. To avoid this in the future-- always use a heavy-enough extension cord and always use a sharp blade. You need a heavy enough cord so that it can supply full voltage instead of more current. The nick in the cord could have contributed to this.
Feb 13, 2013 | Skilsaw "5150" Circular 7 And 1/4 Inch
Skilsaw wormdrive stops working but if I wiggle the cord at the handle it sometime starts and will run until I take my finger off the trigger. Now it won't start at all even after wiggling the co
Replace the cord. Cords get internal breaks by the handle or boot because that's where they have the most bending movement. The wires break inside where you can't see them. When you wiggle the cord the connection is remade, usually with a spark hot enough to hold them together for a short time. When the saw turns off and the cord moves again the weak point breaks again. You can test this by pluggin in the cord and checking for voltage where the cord attaches to the switch.
Jun 28, 2012 | Skil - Skilsaw 77 Saw Hook - / Bosch...
Skil saw 5155 owners manuel
I found something on amazon, take a look here: Skil Circular Saw Model 5125 5150 5155K 5170 5190KC Owner Instruction... . I hope this was helpful. Cheers
Jun 05, 2012 | Skil Saws
MY GIRLFREIND GAVE ME A SKILSAW TABLE SAW AND I DON'T KNOW HOW IT STARTS
On the front of the saw right to the left of the words Skilsaw you will see a large red switch. Pull it out to start the saw and push it in to stop the saw.
Jul 04, 2011 | Skil 10" Table Saw 3400
I have disk read error on my laptop -acer aspire 5520
dear sir
5570z driver winxp download parmistion.
thanking
abhishek mohan
Oct 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Table saw skilsaw model number 3400 15 amp
What you are describing sounds like the power is being interrupted somewhere. In my experience, this is usually casued by a bad switch. Try replacing the trigger switch.
Dan
Oct 19, 2008 | Bosch 7 - 1/4" Skilsaw Circular Saw
Saws Logo
348 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tim Venetis
Are you a Skil Saw Expert? Answer questions, earn points and help others
