Central heat and air
My central heat and air unit is blowing barely ( really weak aircirculation ) but everybody i called said that there is nothing wrong
then why can't it cool my house like it suppose too
my unit is 2 1/2 ton for an 1800 sqft house insulation is great and brand new
    Master:
  • 518 Answers
Without knowing more information:
1. The evaporator coil could be frozen blocking air flow.
2. Dirty air filters will block air flow.
3. If it has a 2 or 3 speed motor, the highest speed should be used by the AC setting. It could be a wiring issue here. You
didn't state if this is a new problem or has it always been this way.
4. If it's a belt driven blower, the belt could be slipping.
5. If its belt driven, you might have an adustable pully on the motor, if so it needs to be screwed in as far as possible for max speed.
I had the same issue years ago. It was like that from the day I bought the house. Mine is belt driven, so I simply bought a larger pully for the motor, thus making the squirl cage spin faster, and I get plenty of air flow now.
That's about all I got for Ya...
Geno
Posted on Aug 02, 2008
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
1996 Honda Passport EX 3.0 Heater runs weak, the fan barely puts any air out, but I can hear it blowing. It also barely puts out warm air. With the temp. lever in cool it really blows. but as I slide it...
Is this a quantity of air problem or quality of the heat from the heater?
If its heat from the heater you need to first flysh and reverse flush your cooling system, includes radiator etc and use a good flushing agent first. Then replace heater water valve.
Refill and bleed out cooling system and get car up to temp.
When hot, feel pipes going into and out of heater matrix. On full heat they should both be roughly same temp, if not , replace matrix cos it must have collapsed.
Have yoy EML light checked at local garage using spec diagnostic tools.
Roger
Apr 24, 2017 | 1996 Honda Passport
Blows out cold air at times
In their effort to try to boost the efficiency of the heating units the fan sometimes runs even when the air will feel really cool...
The fan may start up before the heat exchanger is warm and may run after the heat exchanger has cooled off...
Probably nothing wrong... just the way it is...
heatman101
Nov 16, 2010 | Goodman Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
I have a central heating and air unit. The unit
sunds like the fan bearings have seized up or u have a bad fan capacitor take a screwdriver and spin ith blade to where the air would be coming out the top and if it startswhen u spin it u need a fan capacitor
Feb 23, 2010 | Coleman Propane Forced Air Heater...
CENTRAL AIR UNIT IS NOT BLOWING INSIDE BUT THE COMPRESSOR OUTSIDE IS RUNNING. WHEN I GO DOWN TO THE BASEMENT TO CHECK THE FILTER-THE BOTTOM OF THE UNIT AND THE FILTER IS WATER LOGGED. ORIGINALLY IT WAS...
There may be a leak. You might try shutting it down and taking a look inside. On the other end, there may be something wrong with your components inside. The compressor outside is to provide coolant. Inside, the fans actually cool the air. Make sure all doors are on the blower downstairs, and if all else fails, call a technician. Good luck!
Jun 19, 2009 | Ecoquest Flair Air Purifier
Central heat/air unit for home blows cold air
could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Jan 13, 2009 | Haier HC48C1VAR Central Air Conditioner
Goodman Furnace/AC unit not working 3a fuse blows even after replacement. once thermostat is turned on and clicks to start ac unit the fuse blows
3 amp is standard.the fuse is blowing to protect the transformer.It is telling you that there is a short in the low voltage wiring.Goodman also had an issue with the coil shorting on the contactor.To prevent damage.....i'd call a pro.It should be a fairly simple repair.
Jul 03, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
