Question about Tomtom One XL GPS Receiver
After update, tried to restore data on my device, mac crashes and now my device can locate the map. It's on the device, but it doesn't load.
  • Shirley Felix Mar 20, 2011
    ...can't locate the map on the device.
  • 391 Answers
Hello iff you follow the steps here you will be sorted 1. Make a complete Explorer, not Home, backup of your unit's contents. Ensure hidden files/folders are showing.
2. Go to the location of your downloaded map. you'll find it in this location:
C:\Documents and Settings\yourname\My Documents \ TomTom\HOME\Downloads\complete\ map\
your_map_name
(Substitute your specific map name every time you see your_map_name in these instructions.
It's a cab (compressed) file.
3. Within the compressed cab file, if you look at the contents, you should see a your_map_name.zip file, perhaps a couple of .gif files, a your_map_name.toc file and, importantly, an activation_map.cab file.
4. Use Winrar and extract the contents of the your_map_name.zip file into the current your_map_name map folder on your unit. If you don't have a folder called your_map_name, then create one using Explorer.
5. Then, extract the file in the activation.cab file into the same your_map_name map folder on your unit. You don't need to worry about the other files.
6. Make another Explorer backup of the unit's contents to a different folder on your computer.
7. Disconnect the unit PROPERLY from the computer using the Safely Disconnect icon in your notification area of your desktop.
You are done!
goodluck
Posted on Mar 20, 2011
What are ways for iphone data recovery
You must have a backup in the pc if you choose to use itunes. Check that. This has to be restored on the original or a newer iphone.
Dec 03, 2013 | Apple iPhone 3G
No map data availble
Your Garmin GPS has an internal memory or an SD-card that contains an "operating system" and "map data".The operating system is like windows or Mac OSX. It contains the menu and everything the GPS displays. The "map data" is a digital roadmap the GPS uses to calculate your route. If the map data was on a SD-card that was inserted in your GPS, it could me that you lost the SD-card. That could be the reason your GPS can't find the map data. Sometimes it happens that when people connect their GPS to a computer to update the "operating system" of the GPS something goes wrong. For example, when you disconnect your GPS from the computer while the update software is still writing data to your device, the connection gets lost and you're left with corrupt files on the GPS. It could also be a defect in the internal memory of the GPS. I suggest you try to update the operating system with a program called "Garmin Express" (just google and easy find it). You need to connect the GPS to your computer with a USB cable. Then you can perform an update. I hope it helps to solve your problem. What you could also try is to soft reset your GPS. To do that, you need to remove the silver or blue frame around the screen of the GPS (it pops off). Behind this border there is a reset button.
If the map data is completely gone, and you don't have a backup there is only one solution: Buy the latest map for your GPS online and download it to your GPS. It's expensive. In that case it's better to buy a new device in a shop. Most new devices contain Lifetime online map updates (model name nuvi -then the number - LM or LMT) (LM= Lifetime Mapupdates T= Traffic information) Then you can update your map data every three months if you want.
Nov 08, 2013 | Garmin StreetPilot C330 GPS Receiver
How do I prevent Tenorshare iphone data recovery from crashing every time I try to connect my iPhone?
Hello, firend. iPhone Data Recovery for iPhone 4S is leww likely to crash and DFU mode is not needed. And the bug-fixed version is better than the previous. If it crashes really badly, you can apply for an exchange from Tenorshare.
Contacts Tenorshare on: http://www.tenorshare.com
Mar 07, 2013 | Cell Phones
Mac OS X Computer crashed: how to restore from storejet 25P
Hard drive recovery software is the exact answer for your question how to restore crashed hard drive Mac data. Some days back, due to software conflicts my Mac hard drive was crashed and I was unable to access my data stored in it. I was really tensed because the stored data was very much important to me. Then I searched over the internet and found this software which successfully restored all my lost data and I was very much happy after getting back my data. The software can be downloaded either from official website or by simply clicking here.
Good luck,
Fiona Dsouza
Jul 07, 2012 | Transcend TS320GSJ25P Storejet 25p 320gb...
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
No problem. just trying to download updates. 1 year
Garmin periodically releases updated maps for its GPSdevices. The my Garmin website offers convenient access for managing yourGarmin devices and finding the map updates you need. Garmin offers threeoptions for map updates: free download, single-purchase download or lifetimesubscription. Regardless of which option you choose, the process to downloadmap updates to your Garmin is the same.TOOLSAND INTRUCTION NEEDED TO SOLVE THE PROBLEM1 Connect your Garmin GPS to your computer. Locate theUSB ports on your computer and on your GPS. The GPS ports are typically on theback of the device and may be hidden by a protective cover or rubber cap. Plugone end of the USB cable into your computer and plug the other end of the USBcable into your GPS. Power on the GPS.2 Sign in to my Garmin(see Resources) with your username and password. If you do not have an account,click the Create New Account link to register your Garmin devices.3 Click the my Maps tab to display a list of yourregistered devices and their associated maps. Click the Map Downloads link todisplay a list of available map updates for your devices. Select PC Download orMac Download link.4 If you are alerted to run the Garmin CommunicatorPlug in, click Run. When the Plug in has detected your GPS and is ready todownload the map update, click the Launch Download Manager button.5 At the Save As prompt to save the map update, notethe location or select a new location to save the file. Click the Save button.6 When the Map Update file has finished downloading,click the Launch button.7 At the "Welcome to the Garmin Map Update"screen, click Next.8 After the Map Update USB Driver Check finishes, clickNext.9 Follow any instructions on the Map Update SuccessfulInstallation screen. Click Next.10 At the Software Data and License Agreement screen,select the checkbox to accept the agreement. Click Next.11 After the update installation finishes, click Finishto exit the program.12 Disconnect your GPS from your computer.Thanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
Gps has lost its maps, screen says can't unlock maps
There several reasons you may receive the message Can't Unlock Maps on your nuvi or zumo device.
  • Can you press OK and get to the Where To/View map screen?
  • Did you load maps to the unit using the MapSource or MapInstall program?
  • Did you load maps to an SD data card?
If one of the points above applies to you, please follow the steps below to clear the Can't Unlock Maps message:
  1. Remove SD card from unit, if applicable.
  2. Plug the unit into your computer with a compatible USB cable.
  3. Open MyComputer/Computer icon. (Mac users skip this step.)
  4. Right-Click on the Garmin drive and select Open. (Mac users can locate the Garmin drive mounted on the Desktop.)
  5. Open the Garmin folder.1
  6. Locate a file named gmapsupp.img
  7. Right-Click and delete file named gmapsupp.img
  8. Safely disconnect your unit from your computer to see if the Can't Unlock Maps message is gone.
1. Nuvi 1100/1200/1300/1400/1600/3700 and Zumo 665 users will open the Map folder instead.
*If the gmapsupp.img file does not appear in the Garmin folder, please create an unlock file for device.
Nov 28, 2010 | Garmin Nuvi 265W GPS Receiver
How do you update nextar x4-t if the this model is not on the list to choose from to be updated?
Well, that is going to be near impossible.
You can TRY, with no guarantee, to find out what map company makes the maps for your Nextar. It's either IntelliNab or Odyssey.
Then you would have to load new map data direct from those map companies onto your SD card and pray it works.
From experience it usually ends up crashing the GPS. If Nextar doesn't offer an update, then you're probably out of luck.
Sep 20, 2009 | Nextar X4-T Car GPS Receiver
Map data availability
"I tried to load the new 2008 City Navigator but the update was interrupted."
You deleted your previous maps, therefore there are no maps on the unit. Try reloading the maps again and this time let it continue all the way to the end. It will take a couple of hours depending on loading all maps or only certain states.
Aug 22, 2007 | Garmin StreetPilot c340 GPS Receiver
Tomtom One XL GPS Receiver Logo
97 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
