Question about Garden
Hi, i have a bosch 36v hammer drill and i suddenly stopped working. i pull the trigger and there is nothing happening, sometimes it works but cuts out straight away. any idea of a solution and if i can fix it myself. cheers
    Sergeant:
  • 259 Answers
Make sure the battery connections are clean on the battery and where the battery contacks on the drill. A easy to check the switch is put a jumper wire across the 2 leads that go to the switch and if it runs then the switch is dirty. Clean it with contack cleaner.
Posted on Mar 20, 2011
Bosch ec 1/2 hammer drill trigger doesn't work all the time just stops why?
If it works fine sometimes and at others doesn't, the trigger switch is most likely bad.
May 23, 2017 | Bosch Drills
Hi I've got a bosch 36 vf li and I'm struggling to open it up to change brushes. I've undone all visible screws but still struggling with top part of unit.
Have you removed the 4 gearbox screws? the cover should lift off. sometimes if a brush holder has over heated then the two halves get stuck together in places.
Dec 04, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
I have a Bosch 36v LI cordless drill the batteries are fully charged. However, when I pull the trigger, it starts briefly and then shuts down almost acting as though It's batteries are dead. I have...
One possibility is that the trigger on your drill has a short in it. When you replaced the brushes did you clean off your commutator? I am assuming that you did. You only need to clean the brush dust off of it and ensure the copper contacts are clean. Your issue is definitely with your drill. I am not sure about Bosch but with some drills you can take apart the trigger and check for contamination. Hope this helps.
Oct 23, 2017 | Bosch Drills
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
My hitachi drill is working funny
hi
try to charge the battery at full level and see what happens then.
regards savumihai71
Dec 13, 2009 | Hitachi 18V Lithium Ion Cordless Hammer...
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
