Question about Coleman Powermate Premium Plus 6250W Portable Generator
A pieceof the con rod cap let go an came through the case. it seems this happens all the time the oil level is still acceptable ever techumse owner said the same when same problem happens to every one
    Sergeant:
  • 259 Answers
If the shrowd and cooling fins were dirty the engine could overheat causing the problem of a broken rod. Also if someone set the engine speed higher that could contribute to the broken connecting rod.
Posted on Mar 20, 2011
On a 3.8L what is the aspec diagram and tourque for the racker arm
Hi Juan, I'm AL the owner of Big As Auto Repair
Below is the torque specs for the rocker arm as you requested.
SPECIFICATIONS - TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs. Camshaft Sprocket-Bolt 54 40 - Camshaft Thrust Plate-Bolts 12 - 105 Forged Connecting Rod Cap-Nuts 54 +¼ turn 40 +¼ turn - Cracked Connecting Rod Cap-Bolts (Refer to 9 - ENGINE/ENGINE BLOCK/PISTON & CONNECTING ROD - INSTALLATION) Crankshaft Main Bearing Cap-Bolts 41 +¼ turn 30 +¼ turn - Crankshaft Main Bearing Cap Cross Bolts (3.8L) 61 45 - Crankshaft Oil Seal Retainer Rear-Bolts 12 - 105 Crankshaft Damper-Bolt 54 40 - Cylinder Block Drain Plugs 20 15 - Cylinder Head-Bolts (Refer to 9 - ENGINE/CYLINDER HEAD - INSTALLATION) Cylinder Head Cover-Bolts 12 - 105 Flex Plate to Crankshaft 88 65 - Engine Mounting (Refer to 9 - ENGINE/ENGINE MOUNTING) Powertrain Torque Strut 54 40 - Exhaust Manifold-Bolts 23 - 200 Exhaust Crossover Pipe-Bolts 54 40 - Intake Manifold - Lower-Bolts 23 - 200 Intake Manifold - Lower Gasket Retainer-Bolts 12 - 105 Intake Manifold Upper-Bolts 12 - 105 Lifter Yoke Retainer-Bolts 12 - 105 Oil Filter Attaching Fitting 54 40 - Oil Cooler Attaching Fitting 27 20 - Oil Filter 20 15 - Oil Filter Adapter-Bolts 28 - 250 Oil Gallery Plug 27 20 - Oil Pan-Bolts 12 - 105 Oil Pan Drain-Plug 27 20 - Oil Pressure Switch 23 - 200 Oil Pump Cover Plate-Screws 12 - 105 Oil Pump Pick-up Tube-Bolt 28 - 250 Oil Dipstick Housing-Bolts 48 35 - Rocker Arm Shaft-Bolts 23 - 200 Spark Plug 16 12 - Thermostat Housing 12 - 105 Timing Chain Case Cover -M8 Bolt 27 20 - -M10 Bolt 54 40 - Water Pump-Bolts 12 - 105 Water Pump Pulley-Bolts 28 - 250
Should you need extra help visit my website here: http://www.bigasautorepair.com/
Apr 15, 2015 | 2005 Chrysler Pacifica
NEED DIAGRAM FOR LOCATIONS OF CRANKSHAFT PULLY,OIL SLINGER AND SPRING.FOR 1983 MAZDA 2.2L DIESEL
Here is the procedure:-
  1. Remove setscrew from side of cylinder block.
  2. Remove oil pipe attaching bolts.
  3. Remove oil pump and strainer.
TIMING GEAR COVER
  1. Remove timing gear cover to case attaching bolts.
  2. Remove timing gear cover and gasket.
CAMSHAFT, CRANKSHAFT, IDLER & INJECTION PUMP GEARS
  1. Remove oil slinger and washers from crankshaft snout.
Using puller set 49 0839 425C or equivalent, remove crankshaft timing gear, Fig. 3.
  1. Position a clean rag between camshaft and idler gears, then remove cam gear lock bolt and washers.
  2. Using puller set 49 0839 425C or equivalent, remove cam gear from camshaft, Fig. 3.
  3. Remove idler gear to spindle retaining nuts and washers, then remove idler gear and spindle assemblies.
  4. Remove injection pump drive gear.
  5. Remove timing gear case to cylinder block attaching bolts, then the timing case.
CAMSHAFT
  1. Remove tappets from cylinder block.
  2. Remove camshaft thrust plate to cylinder block retaining bolts and washers, then pull camshaft from block.
  1. Remove connecting rod bearing cap retaining nuts and bolts, then separate bearing cap from connecting rod.
  2. Using the wooden handle end of a hammer, push the piston and connecting rod assembly outward until piston rings clear cylinder bore. Remove piston and connecting rod assembly through top of cylinder block.
  3. To separate piston from connecting rod, remove piston pin retaining clips, then press pin from piston using a suitable driver.
CRANKSHAFT
  1. Remove rear oil seal cap retaining bolts, then the cap and seal.
  2. Remove main bearing cap to cylinder block retaining bolts, then the main bearing caps and thrust washers.
  3. Lift crankshaft from cylinder block.
I’m happy to assist further over the phone at https://www.6ya.com/expert/uttamjeet_2f3adc18600f8ede
Mar 26, 2015 | Mazda Cars & Trucks
Pull rope will not pull motor locked up?
If the crankshaft won't turn at all, either by the pull rope or by turning the flywheel by hand, it's usually because the connecting rod from the crankshaft journal to the piston is seized to the crankshaft. This is usually caused by running the motor with oil in the crankcase. Worst case you'll have to replace the crankshaft and con-rod. In some cases the journal on the crankshaft can be cleaned up and with a new con-rod you'll be able to use the motor again.
Feb 28, 2013 | Garden
Torque settings conrod bearing 2e engine
tighten with a rachet and a decent socket with the shape of the nut in the end ,tighten to about a grunt and a slight arm muscle strain which is about 50lbs ,in two staged in the book it says 22nm +90? which to me is a load of hog wash ,make sure the shell with the hole in it for the oil spray is in the top con rod end and bit of grease in their as well before you fit the bottom one then a pull down first time with a rachet to firm pull then the second pull ,then turn engine over to make sure its not locked up then do the next one ,the lips in the shells that hold the shell inside the caps normally go together on one side and the con rod oil spray hole should spray towards the thrust side of the piston .
Feb 25, 2012 | 1990 Toyota Corolla
How can i tell if my crankshaft bearing is going out
Hi, if the big end bearing fitted within the con rod on the crankshaft fails it is accompanied by a knocking noise when the engine is running, when the engine is striped and the crankshaft is out, movment of the con rod in an up and down direction while grasping the conrod between finger and thumb indicates big end failure, youmay also notice while rotating the con rod that it locks up, more so in 1 direction. Visual damage bearing cage failure visible from within the oil cut out on the big end of the conrod,
Crankshaft main bearing failure, the main bearings are fitted within the engine cases 1 left and 1 right, failure of this bearing would be movment of the crankshaft ends within the cases, accompanied by a rough vibrating sound.when running,
Hope this helps paul
Feb 23, 2011 | 2004 KTM EXC 450 Racing
Have just purchased 1975-76 Z900 cant find any means of checking engine oil level
On the right side case cover, at the bottom towards the rear, there will be a sight glass.
If the oil is dirty, it seems hard to find because it blends in with the motor.
Just remember this, if it has a sight glass, usually the oil cap does not have a dipstick.
If the oil cap has a dipstick, then that is you means of checking oil level
Dec 12, 2010 | kawasaki Z1 Motorcycles
Oil level light show
Check the oil level. engine off; open hood; pull dipstick; wipe with rag and replace. Then pull out again and read the oil level. If it is at the lowest acceptable level, you need to add one quart. If below that, add more. On the valve cover, there is a cap that comes off for you to pour the oil into. Add some oil, wait a few seconds, then check level again at the dipstick. Do not overfill.
Check your owners manual for which oil to use - normally will be 5W-30, but go with the manual's specification.
Jul 26, 2010 | 1991 Toyota Previa
What is the fork oil level after replacing seals
Here is a manual for your bike....search for English parts of it.....
http://safemanuals.com/user-guide-instructions-owner-manual/HUSQVARNA/CR%20125-_M
The manual has directions for taking out parts, putting in SAE 5 or SAE 7.5 fork oil, and then measuring the distance from the top of the fork tube to the top of the oil. It should be 3.5 inches. That doesn't sound right, but maybe that is with the forks compressed, the directions may be indicating that. You could judge by the amount you drained out of the forks. Here are the directions in the manual.......
OIL FORK LEVEL
For the regular fork operation,
both legs must be provided with
the necessary oil quantity.
Remove the forkrods from the
fork to check the oil level inside
the forkrods. Work as follows:
- remove the power rod caps;
- remove springs from the stems
letting the oil drop into the
latter;
- bring forks to stroke end;
- check that the level is at
distance “A” below the upper
limit of rods.
(distance A is 3.5 inches)
Oct 03, 2009 | 2002 Husqvarna CR 125
How do you check oil level? what is the correct way to do it?
un do the oil cap ond there is a stick on it to measure it
Jul 30, 2009 | 1999 Honda V-Twin Magna
How to remove the Harmonic Balancer on a 1995 Toyota Camry sedan?
4. REMOVE ENGINE BALANCER
(a) Uniformly loosen and remove the 6 bolts in several
passes, in the sequence shown.
(b) Remove the engine balancer and spacers
5. CHECK CONNECTING ROD THRUST CLEARANCE
Using a dial indicator, measure the thrust clearance
while moving the connecting rod back and forth.
Standard thrust clearance:
0.160 − 0.312 mm (0.0063 − 0.0123 in.)
Maximum thrust clearance:
0.35 mm (0.0138 in.)
If the thrust clearance is greater than maximum, re−
place the connecting rod assembly. If necessary, re−
place the crankshaft.
6. REMOVE CONNECTING ROD CAPS AND CHECK
OIL CLEARANCE
(a) Check the matchmarks on the connecting rod and cap
to ensure correct reassembly.
(b) Remove the 2 connecting rod cap nuts.
(c) Using a plastic−faced hammer, lightly tap the con
necting rod bolts and lift off the connecting rod cap.
HINT: Keep the lower bearing inserted with the con
necting rod cap.
Mar 07, 2009 | 1995 Toyota Camry
Coleman Powermate Premium Plus 6250W Portable Generator Logo
32 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
