Question about Metra Toyota Lead To Oem Radio 94 87
I NEED THE WIRING DIAGRAM FOR THE INSTALLATION AND WHAT ARE THE PIN CONNECTIONS FOR TOYOTA RADIO PN 08600-00908
I have a Garmin 2010c on my boat and turns off every 10mins.. what can be the problem?
Bad connection or a fault to the unit.
Do you have it on a separate battery? It is best if they are, or connect direct to the starting battery, not connected via power that you find in the console or on a power bar.
Make sure you are using good quality copper stranded wire of the correct gauge with soldered or properly crimped connectors. I think it is 18 gauge, but your installation instructions will guide you. Also mentions 24 AWG. Manual states;
Wiring
There are two wiring diagrams provided for you convenience. The first is a simple hook-up showing the GPSMAP 2006/2010 (using the 18-
pin wiring harness), the GPS 17 and the alarm circuit. The Alarm does not have to be wired for the unit to function. The second is a complete
wiring diagram showing the GPSMAP 2006/2010 (using the 18-pin wiring harness) interfacing with a variety of different equipment. The extra
5-pin wiring harness that came with the unit is intended for future interfacing features and does not require connection. Refer to the wiring
diagram that will best suite your needs. Make sure that all connections are good. For extra lengths of wire, 24
AWG (unless otherwise noted on
wiring diagram), shielded, twisted-pair wiring is recommended. We advise soldering all connections and sealing the connection with heat shrink
tubing. If you experience difficulty wiring the unit, please contact an installation professional in your area.
Make sure the connections are good on the rear of the unit including plugs to the transducer. You can coat with a little Vaseline which his electrically conductive.
States the unit is susceptible to RFI and should be 3 feet away from a radio antennae.
Finally, make sure the inline fuse and connections to it are good.
If all that seems good, the first thing to do is swap out the transducer for a new one. Still does it? Send the unit for repair.
Does it also do it at rest in the marina, or do you trailer the boat?
I have a Humminbird 998 HD Si.
http://static.garmin.com/pumac/47_2006_2010_GPS17Installation.pdf
Jul 29, 2017 | Garmin GPS
I need the wiring diagram for a Toyota AD6801 model 09355959 radio
If it is the one that came with the vehicle, Google
year make model (of the car) wiring diagram
and look at the images tab. The wiring diagram for the car shows the wiring for the radio.
There is this site as well
http://www.tehnomagazin.com/Auto-radio-car-connector/TOYOTA-Car-Radio-Wiring-Connector.htm
Google
Jan 09, 2017 | Toyota Cars & Trucks
Clarion PN.9967H speaker wireing
need wiring diagram for Clarion pn:9967h car radio in 1998 Nissan frontier, right hand drive please
Nov 23, 2013 | Car Audio & Video
Need wire diagram for 1994 toyota windom
Whether your an expert Toyota Camry mobile electronics installer, Toyota Camry fanatic, or a novice Toyota Camry enthusiast with a 1994 Toyota Camry, a car stereo wiring diagram can save yourself a lot of time. Automotive wiring in a 1994 Toyota Camry vehicles are becoming increasing more difficult to identify due to the installation of more advanced factory oem electronics.
One of the most time consuming tasks with installing an after market car stereo, car radio, satellite radio, xm radio, car speakers, tweeters, car subwoofer, crossovers, audio equalizer, car amplifier, mobile amp, car amplifier, mp3 player, ipod or any car audio electronics is identifying the correct color car audio wires for your 1994 Toyota Camry.
The Modified Life staff has taken all its Toyota Camry car radio wiring diagrams, Toyota Camry car audio wiring diagrams, Toyota Camry car stereo wiring diagrams, Toyota Camry car radio wiring schematics, Toyota Camry car wiring diagrams and cataloged them online for use by our visitors for free. Our automotive wiring diagrams allow you to enjoy your new mobile electronics rather than spend countless hours trying to figure out which wires goes to which 1994 Toyota Camry part or component.
Jul 26, 2012 | Compaq Presario AMD V120, 2GB, 160GB HD,...
Need wire diagram for 2001 toyota tacoma for installing JVC kw-nt3hdt stereo or any advice
Hi, here are your factory wire colors/functions. Aftermarket stereos have a common set of colors, which should be in your installation diagram. The process is simplified if you purchase a wiring adapter for your vehicle. These are available for under $10 at most WALMARTs and auto parts stores or about any place that sells car stereos. In either case, I recommend you solder the connections or at least use crimp terminals. If you have any more questions, please let me know--I've done a lot of stereo installations.
2001 Toyota Tacoma Car Stereo Installation Guide
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jan 07, 2011 | 2001 Toyota Tacoma
I HAVE A 1990 TOYOTA CAMRY AND I NEED A WIRING DIAGRAM FOR RADIO INSTALLATION.
does this help, or do you need more?
1990 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 3 1/2?
Front Speakers Location: Dash
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Oct 17, 2010 | 1990 Toyota Camry
I need a radio wiring diagram for a 1992 toyota pickup
Installation guide for 89-95 pickups:
http://www.installdr.com/InstallDocs/Toyota/PDF/869017.pdf
Oct 14, 2010 | 1994 Toyota Pickup
Need Toyota wiring diagram for Radio Model 86120-04090
truble i get a radiocassete model 86120-02071 need the wiring power o aoutput spekers diagram
Dec 23, 2009 | Metra Toyota Lead To Oem Radio 94 87
Need a wiring diagram/pin up sheet for Fujistu ten radio up
Request the wiring diagram directly from Fujistu.
Jan 13, 2018 | Car Audio & Video
Metra Toyota Lead To Oem Radio 94 87 Logo
96 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
