Heavy vibration - Televison & Video
  • mooselegs Mar 21, 2011
    im experiencing a heavy vibration in my power subwoofer connected to my surround sound receiver. i removed subwoofer from its box. didnt see any cracks or breaks inside. this vibration doesnt happen all the time, it recently started when i connected a blue-ray system. im leaning towards an interference problem. any advise?
  • Televison & ... Master
  • 1,229 Answers
You did not give a model as to which specific TV is having problems. I did have one flat screen that did the same thing. In this case it was a speaker that was not tight fitting in the chassis. In other cases, I cannot recall this problem. I have seen home theaters with this problem. The fix here, was replacing the large capacitor in the subwoofer. Thanks for asking and show a few hands of support!
Posted on Mar 20, 2011
Vibrates real bad in spin mode.
Check to see if the washer is level, and adjust the leveling legs if necessary. Always lock the legs in place after adjustment to keep them from getting loose as they do work themselves loose during heavy vibration conditions.
The following items could cause the vibration problem:
1. Clutch assembly
2. Vibration dampers that support the tub. Should one or more be faulty, always replace all four simultaneously.
Feb 24, 2016 | LG WFT1071TP Top Load Washer
BOTH CV AXLES & TORQUE AXLE REPLACED. UPON ACELL GET VIBRATION GOES AWAY AT ABOUT 25MPH. WHERE IS VIBRATION COMING FROM?
Check for a worn universal joint on the drive shaft going to the rear wheels.
Check your transmission fluid level. (Low level can cause vibration on acceleration.)
Check to see if your transmission filter needs changing.
Does it only vibrate under heavy acceleration?
May 04, 2015 | 2006 Honda Ridgeline RTL
Heavy vibration when turning
Does it do this on both left and right turns? It might be a CV joint if it is only left or only right turns.
Sep 24, 2014 | 2004 Acura MDX
Milnor mwr18j6 vibration switch tripped
Load was out of balance (to Heavy with water, to many Jeans etc.)
Open washer and look at switch, it may be stuck or the switch is bad and the load was not to heavy.
Good luck
May 10, 2014 | Milnor 09R020 - Vibration Switch
2003 F350 6L Diesel, 6 speed manual transmission. Vibration/noise right front when under medium to heavy acceleration, vibration/noise becomes very prominent starting at 1900 rpm in all gears (still can...
Rob, assuming this is a 4X4? Sounds like a bearing. They can vibrate, snap, clunk, all kinds of terrible noises or vibrations.
Axle u joints will also do this. Is it all wheel drive?
Nov 02, 2013 | Ford F-350 Cars & Trucks
Excessive vibration in Ryobi RY30120 trimmer
the center bushings that holds the shaft center are worn and need to change. this damage is caused bu using a to heavy nylon and because of the damaged you will get vibration on all attachments used
Aug 03, 2012 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
VIBRATION AT 60MPH OR BETTER
try and rotate the tires if on has a problem the vibration will change to the rear
Jun 14, 2012 | 2004 Oldsmobile Alero
Compaq presario CQ61 is making a vibrating noise. it is constant
Two things,
1) Check if you have a CD/DVD in the disk-drive and remove it. The spinning disk is causing the vibration
2) Go to START > Control panel > PERFORMANCE AND MAINTENANCE > POWER OPTIONS >
In the middle of the dialog box, you should see a box that says "Turn off hard disks".
There you can select "After 3 minutes" or "After 5 minutes". This will turn off another spinning/vibrating thing if you have an issue with imbalance there.
3) Make sure you are not blocking the vent holes on the bottom of your laptop so air can get through and it doesn't overheat. The last spinning thing on your laptop is the cooling fan. This only comes on when it is hot. If you are doing a lot of calculations or heavy-duty computing will also make it hot but this is very rare (I guess some games can also be considered heavy-duty computing and cause overheating). If you are doing heavy-duty computing, there is nothing that can be done about he vibration of the cooling fan.
Good luck
May 06, 2011 | Computers & Internet
Feeling a vibration in the bike only in gear at the 3-3.5k rpm range that the only way i can think to explaing is a feeling of a sticky bearning. does not do it in neutral
It could be wheel/tire balancing issue if you only feel the vibration at highway speeds (60 mph and above) then higher speeds it goes away.
I've worked with tires and rims on trucks, bikes and cars and have found that a harmonic vibration is usually caused by tires being out of balance.
Perhaps the dealer could check for a vibration on a dyno.
For the DIY bikers.....Use CAUTION but, the Old school routine would be to raise the wheels (heavy duty Bike Jack) strap it down and spin the tires by hand and check the rims for run out (to the sides) and the tires to see if they are round and true.
Then spin the rear tires to speed (3500rpm) to see if the shaking/vibration is there. Also rotate/spin the front tire and see if there is a heavy spot that will settle to the bottom. Add a the appropriate weight (1/4 oz stick on weight) to the opposite side (180 degrees) of the heavy spot. Spin again and see if totally random spots settle to the bottom. Road test and see if it improves.
Oct 05, 2009 | 2008 Harley Davidson FLHX Street Glide
Front end vibrates when braking
I turn them on a brake lathe in my shop whenever I change brake pads for customers. Heavy repeated braking will make em warp and vibrate like that. also changing the pads without turning them on a lathe will often leave them warped. Usually caused by either overheating during heavy braking effort or very commonly, using too heavy an impact wrench to tighten the lug nuts up. Did u get your tires changed recently? if so, dont go there again. their impact wrench is not set right and is likely overtightening the lug nuts.
Get a local garage/NAPA to turn the rotors and replace the pads. If the vibration is very severe you will have to replace the rotors.
Hope this helps if so pls rate my answer!
Jan 07, 2009 | 2006 Dodge Ram 1500
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
