I washed a throw rug that the backing all came off in tiny pieces. now the water wont drain out of the washer
    Sergeant:
  • 192 Answers
You probably have a stuck drain line.
Mover the washer out and remove the drain tube. It should be held on by a few screws. Make sure you have some towels handy. After removing the hose clear out and debris and re-attach. If it still does not drain repeat the process until all debris has been removed.
Posted on Mar 20, 2011
Not draining
take the bottom panel off and check and clean drain pump filter
Feb 27, 2014 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Washer not draining
sorry about this problem,we get this alot your drain pump is clogged,so try this take cloths out and see if you can scoop out water.Now put rooto-roter drain opener in drum and let it sit for about 1-2hrs.Now run on heavy-duty by itself it may have to go through 2 cycles,to clear out clogg.See the drain pump is real small,so dog hair,strings,or pieces of rubber from throw rugs well clog pump.So first try this.
Jul 07, 2010 | Frigidaire GLTF2940ES Front Load Washer
LG washer won't drain
you probably didnt get it all may need to clean it out 3 or 4 x
Apr 16, 2010 | Washing Machines
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not empty water, wife washed backing came off
in the pump its at the bottom of the machine and where the drain hose hooks up. youll have to tilt the machine to get to it
Feb 25, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Help!
When the backs of the rugs fall apart, they tend to bunch up in the pump and form a pasty substance that keeps the motor from turning. Since the unit knows there is more water in there than what should be, it tries do keep draining even when the unit is turned off (the buzzing noise you're hearing) The first thing you need to do is remove the lower front panel (the screws are on the botom side of it. Once you take those out the panel (with a little wiggeling) will come down then out. On the bottom of your washer, you will see a white piece of plastic. This is your pump where the remanants of your rugs have ended up. I would recommend a large bowl, towels and a wet/ dry vaccume at the ready before the next step. On the front of the pump, there is a knob whcih you turn counter clock wise to open. I recommend putting the edge of the bowl under the pump while you SLOWLY turn the knob. DO NOT OPEN IT ALL OF THE WAY INITALLY! Drain water out a little at a time. Once your bowl is full, screw the knob back in, dump the water and repeat until all of the water is out. Once the water in not flowing anymore, then open the knob fully and pull it out. You will see a white clump of the rub backing.Once you dispose of it, fill then drain your washer again. More remanants of the rug will wash into your pump. Continue this fill, drain pump clean procedure unit the trap comes out fairly clean (it will take many loads to get the last bits out from everywhere inside your washer)
Jun 17, 2008 | GE WBVH6240F Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
Spins but water won't drain out.
Yep that rug backing has totally clogged hoses, drain pump.
will have to be dissasembled and cleaned. You could try some creative things like using air pressure to try and clear the tubes.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
