When i press e it's write morthan ten times and no stop please help me
  • 122 Answers
Hello, Try and see if you can take off the cape on the key then scratch it gentlely and close it back try it again and see if it will work. Please vote me when you try it.
Posted on Mar 20, 2011
    Problem Solver:
  • 8 Answers
Dently pop off the key cap.......just the letter e with a small plain svrewdriver.
Clean under and around the little switch now visible. Clear away any dust,crumvs and debris. Clean the area again and recheck
If there is no improvement call me on 07766 054288 for more help.
I need code for lm1075 universal remote on a Sylvania tv
Press the power button and the button for the device to be programmed, holding them down until the red light comes on. Release the buttons at the same time. Pointing the remote at the device to be programmed (while the device is on), press the PLAY button. The red light will flash 10 times as it Foss through ten codes. If the device turns off, press the REWIND button once every few second until it turns back on. As soon as it turns on, press the STOP button. You May have to go through several sets of the ten codes to get to the right one. Press the play button after each set of ten if you haven't had tor device turn off. After you have the device coded, hit the device button, then power, to make sure you have it programmed. Good luck. I just had to do this myself. I had memorized how to do it, threw away the manual, then forgot. I couldn't find any help online, so I played with it until I figured it out.
May 06, 2015 | Sylvania Televison & Video
Hi. my calculator canon f 604 is acting wierd. when i press 10 EXP 2 , it gives me 1000 instead of 100. please help me out there is a problem in my calculator. for each exponent it gives one extra like...
You're getting the correct results. The "EXP" means "times ten to the". When you press 10 EXP 2, you're asking for 10 times ten to the second, which is 10 times 100 or 1000. If you just want ten to the second, press 1 EXP 2.
Apr 23, 2011 | Canon F604 Scientific Calculator
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
Sony HCDX1 STUCK IN DEMO MODE
I don't have a Sony HCDX1, so if this doesn't work, please do not rate me down.
Push the PLAY and STOP buttons (at the same time) and hold them for about ten seconds. This should get you out of DEMO mode.
Power the unit off, then back on. If the display now says LOCKED, then press the PLAY and STOP buttons (at the same time) again to unlock.
If this does work, please rate it Solved, so others can use this solution. Thanks!
Dec 23, 2008 | Sony DAV-X1 System
Reprogram RCA Remote to Sony Television
1 Turn on the component you want to program.
2 Press and hold both the TV/DVD/ect button and the power button untill the light comes on and stays on
3 Press the play button every 5 seconds until the device turns off. A bank of ten codes is being sent each time.
4 Press the rewind/reverse button to see if it turns off/on again. Wait 2 seconds and press again until it turns back on.You may have to do this up to 10 times until it searches through the bank of ten codes sent.
5 Press and hold the stop button until the light goes off. This saves the code.
Nov 03, 2008 | RCA 3-Device Universal Remote with...
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
Leappad won't turn on
If you press the power button and the home button at the same time, count to ten while holding them down together, then let the buttons go after a count of ten, then press the power button, it should turn on. this is a reset for the leappad. most times works in most cases.
Jul 25, 2008 | Toys
Computers & Internet Logo
David Payne
David Payne
