Question about Garden
The mower runs great, but when I put the mower in reverse and start to come up on the clutch , the mower starts to go dead? What is making it do this. How can I fix it? What is the mower #so I can order a manual Donna
    Brigadier General:
  • 3,911 Answers
If you have your hands and eyes on the mower and can't find the maker's riveted on label, how could someone else who can not even see it? help yourself, often along one side or the other of the front of the frame or under the seat or stamped on the rear end.
it has a safety switch to keep you from backing up with the blades running, most have had that for years. too many daddies backed over their little kids turning them into amputees, and the manufacturer's got tired of the lawsuits.
Posted on Mar 21, 2011
I have a LT1042, cub cadet. PTO clutch burnt up. I replaced it and the solenoid, fuse, and relay. Thinking that when PTO clutch burnt out that something else like a wire or sensor went out also.
Check all the safety switches u have a bad one look under the seat first that one is a common problem so I take it your PTO won't engage I bet your old PTO is still good the safety junk they put on these mowers fails a lot causing problems running your mower also look under the back side by the tire there is another safety switch that gets corroded that's switch is the one that will not let you mow in reverse if you want to bypass it u can just put the wires together then beware your mower will work in reverse also I hope this helps you have a great day Regards Chris
Aug 03, 2016 | Cub Cadet Garden
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
Tranny, linkage or ???
clutch, and check clutch cable linkage. Make sure there ain't no or very little slack in the clutch cable. It dies because the clutch is still engaged with the flywheel. Car won't move in any gear because the clutch prolly needs to be changed.
Feb 06, 2014 | 1987 Acura Integra
Mower starts but drives very slow or not at all, but fine in reverse.
If this is a hydro unit and it drives fine in reverse then there is no reason why it will not do the same in forward, there is a variable swash plate in the unit to change from reverse to forward, i would be looking at the linkages, if there is not enough movement it will greatly affect speed, check also that the pulley on top of the hydro is tigh and has not stripped the splines.
Apr 14, 2012 | Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Engine runs will not go into gear and brake does not work
You have to disengage the transmission if automatic, There is a lever in the back pull out and up. then try to push, also make sure that the brake is off.
Jan 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
