Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
My ink holder wont come out - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
  • 823 Answers
Unplug your printer for 30 seconds to one minute and then plug it back in. turn it on, and press and hold the "power button" until the carriage comes front and center.
Posted on Mar 20, 2011
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
I dont have any coloured ink cartidges left and need to immediately print some forms in full black will be okay but i cannot change my colours to black as the ink holder stays on the far right of my epson...
To print in all black, you can change a setting through the computer to tell the printer to only use the black ink. This is better than putting black ink where the color ink normally would go as that would cause the shading to be wrong and potentially ruin the documents.
If you have enough black ink in the printer, before you finalize the printing process make sure you have black and white only selected.
This will allow you to print without getting access to the ink cartridge holders.
Good luck hope this helps.
Mar 11, 2011 | Epson PRINTER, 4800 PORTRAIT EDITION...
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
Pixma mp8300 shows error code 6A00 and wont work at all
The problem is inside the printer. Turn off the printer and open the replacement ink compartment- move the inks holder far to the left- use a torch to check where the inks holder home and you'll see that there is a sponge a tiny rectangular shape come loose -use the twiter and put back in place (holder).
http://www.fixyourownprinter.com/forums/inkjet/39177
Apr 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
The ink cartriges wont fit into the printer.
This printer uses PG-30 and Cl-31 ink tanks. You can also use PG-40 and CL41. Open paper output tray. Turn on the machine and lift up the scanning unit or printer cover. Pull unit support down into place and the ink holder will move to the left. Gently remove cartridges and install new ones. Let me know of outcome.
Jun 08, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Wont work F380 All In One
first you should replace the both cartridges and take a cotton cloth then clean the outer surface of the cartridges then also clean the inside path of cartridge holder or carriege. Remember a very light scratch on the cartridge circute,it will never work.
Jan 13, 2009 | HP DeskJet F380 All-In-One Printer
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
T.Boopathy
Jul 22, 2008 | HP PSC 1610 All-In-One InkJet Printer
YELLOW INK LOSE
Take all carts out. Have a close look into the cart holder. If you have lost ink it will be beneath the cart holder! That might be because the cart holder leaks. You need a new cart holder then. You have to open the printers top cover, carefully take the holder out, clean the bottom of printer and replace the holder with a new one.
This happens sometimes because the glue which fastens the foil (this is the bottom of the holder!) lost its adhesivness.
Feb 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
23 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
