Question about Jandy Aqualink Rs4 One Touch Control System Control System
When spa button is pushed, the spa circulates but water starts to drain out
  • 3 Answers
You have a broken motorized valve broke. you should have two black boxes with handles at your equitment pad have some one push the spa button while you look at the vavles if one doesnt turn thats your broken on.
Posted on Mar 24, 2011
The spa has come up with thermal cut off see user guide?
Water at the sensor has reached an unsafe tempurature. Check for proper water flow. There is usually a small button to push in to reset the sensor, it may be a red button the size of a pencil eraser or the same but behind a black rubber boot. Almost always located on the spa heater pack. Try removing the filter and running, if it continues to operate and heat, replace the filter. If not check the circulation pump for proper operation.
Apr 26, 2017 | Pool & Spa
Spa won't start after cleaning. What might be wrong?
After draining a spa it is common to get an air lock in the plumbing. Depending on the manufacturer or plumbing configuration will determine the easiest way to accomplish this. The concept is the same, help the water to start moving. Either relieve the air down low, i usually loosen the pump drain plug until water sprays out or force water through the plumbing in the natural direction of water flow. Those little 24 hour circulation pumps are usually the biggest culprit for this problem.
Apr 25, 2017 | Pool & Spa
I have a Aqualink RS6. When I push the "Spa" button to circulate water from the spa, to the heater, back to the spa, then the spa begins to empty! What do I fix or replace?
it sounds as if the actuator returning the water to the spa is not responding. when you hit spa, the 'draw' and 'return' valves must be in the right position. if the draw switches to spa but the return stays on pool, the spa will drain
Jul 19, 2014 | Jandy AquaLink RS2/6 All Button Dual...
We have a brand new Oasis Mohave spa and we wanted to run through a full cycle so we ran the tub for a week, no problems. then we drained and refilled the tub. Now we get dr or dy as error codes on the...
The dr error code is for "dry". Meaning that the control system is not sensing that water is flowing through the heating element.
With a new spa, and you just having drained it , it is probably an air locked pump.
What this means is that you have a small constant circulation pump with not much power, that got ait trapped in it when you drained. When you went to start back up, this "air lock" prevented the pump from fully priming.
Power down the spa at the breaker. Remove the filter element.Stick a garden hose with lots of pressure into the skimmer hole and open the hose valve to let water inject into the skimmer.
Restore power to the spa and check operation.
If after attempting this a few times you still get the code, there is an issue with your flowswitch, or with your circulation pump.
With a brand new spa, id like to hope that you just have an air lock.
Good luck
Mar 16, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
Just bought house with aqualink pool spa, one of our teenagers pushed the buttons, we dont know which one and the spa has emptied and the pool is full and we dont know how to get the water back in the spa...
You cannot drain the spa using the indoor controller, unless the valves out at the equipment are set wrong. go to the outside pannel and put the system in" service mode"(using the button on the left). then push the button on the right till it says "spa fill".There are 2 "accuators" (or automated valve turners) They are black rectangular boxes connected to the water valves. Use the toggle switches on the side to turn the vales to the correct positions. You want the pump to **** from the pool and return to the spa. Now turn on the filter pump and let it run till the spa is full. Put the system back in "auto mode" and you are done.
Oct 28, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
No jet flow hot springs highlife 1990
you might have an air lock, when you first start filling the spa, start the water running in the skimmer first. that should force air out of the pump and should pick up prime right away. if not, you may have a valve problem.
Mar 30, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
No heat for the spa.
go to the heate and see if it tries to start and report back on any noises you hear or click or fans or is you smell gas
Jan 03, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
87 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
