Question about Liebherr HWS1800 (1.7 cu. ft.) Wine Cooler
The wine portion of our Liebherr will not cool. We arrived home yesterday after a week long visit away and arrived to find the alarm on the freezer sounding. Apparently not closed all the way when we left. Lost most of our freezer food, and cleaned it up, and now freezer working, but icemaker not working, and wine cooler not cooling. It's been 20 hours. can you help. the manual and troubleshooting guide/no help
    Genius:
  • 1,400 Answers
Hello
It usually takes 24 to 32 hours for the unit to level out.
Put the t stat on high or max and let it run until desired temp is reached.Check that ice maker fill arm is in down position.
Posted on Mar 20, 2011
The red alarm light has came on on my liebherr Chester freezer but it is still freezing what could be wrong with it?
Items will freeze at 31 degrees F, but normal freezer temp. is 0 degrees F- you should measure the temp inside the unit and be sure it is near 0...
Jun 04, 2016 | Liebherr Freezers
How do i reset my Liebherr Premium Freezer, the freezer is not cooling and making ice
It needs professional service. If it is out of warranty, you'll need to call a service tech for a visit.
Nov 26, 2014 | Liebherr SBSes 74S2 Premium NoFrost
The top part of the freezer compartment is warming up and setting off the alarm. Liebherr 7080 207-01 model
I also had defrost problem with Liebherr 7080 207-01. I removed freezer back panel, I defrosted all ice with hair dryer, but the freezer is not done for manually defrosting!!! You may have problems removing the back panel (I was not able to remove it with a screwdriver and i decided to pull it beaking the plastics supports and thean I put it back. It is a shame !!! Now it is working much better. I think this will be my last Liebherr freezer!
Oct 18, 2012 | Liebherr Refrigerators
Help! In 2006 I purchased a used RV with a dometic model 2408 refrigerator that did not work. After reading up on Absorption refrigerators and repair facilities I had it rebuilt by RV Mobile in Everett,...
The evaporator coil is usually located in the freezer compartment, and there are ducts with dampers that send cool air to the refrigerator. It sounds to me like that may be your problem. It seems that if you move the appliance around a little, (cleaning it and the like), then for a short period you start to get a semblance of cooling. Hope this helps
Sep 10, 2009 | Refrigerators
Motor very hot; not cooling
If the compressor is hot it is possible that it is short cycling. Make sure the compressor is running and that the condenser fan motor is running if air cooled.
Mar 07, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Koolspace wine cooler
I have the Vintage Keeper Odyssey. I had the same thing the other day. Unit is 7 years old. Vintage Keeper web-site suggested to unscrew the control box and remove. (The box with the "Set" and Up and Down arrows. Unplug the wiring and sensor on the back and then plug back in. Plug in the unit and text. It took my "AL" away.
Unit doesn't cool very well. A coolant leak may be my problem. I was looking for solutions other than buying a new refrigeration unit.
Jun 07, 2008 | Vintage Keeper Koolspace chillR Cooling...
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
Liebherr HWS1800 (1.7 cu. ft.) Wine Cooler Logo
204 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
