Question about Logitech Computers & Internet
I was deleting things in add remove hardware and now my logitech x 240 speakers have stopped working, i also had a yellow ? appear in device management but i have downloaded something that seems to have corrected that but still no sound. whenever i try to play something through media player it tells me it could not be played as there is a problem with my sound device - help!! :-)
  • 823 Answers
There are two possibilities here which may be causing your problem.
Either you have not gone back in and enabled sounds in the control panel or you need to reinstall the speakers in the hardware manger and set the options to use them. That is "if" you have not deleted your sound card drivers?
to enable sounds, go to control pane, and then sounds and double click on it. Check to see if there is a sound sceme chosen (i.e. windows default). If there is no sceme chosen and its greyed out, click on the arrow and choose windows default and save it. It will tell you that your previous sceme may be lost if not saved first and ignore that warning - just continue.
Click the test option next to the sceme chosen and see if you can hear it?
If not, then continue troubleshooting and move to the next possible problem which is reinstallation of your speakers through the hardware manager.
Go to the control panel and find install a device or hardware manager (depending on which version of windows you are using). click on it. Windows will try and find the device you wish to install, if it locates the speakers then great just follow the prompts until installed. Then make sure the sound it turned on as indicated above and your done!
If it does not auto find the speakers you want to install, change the options to locate the item you wish to install yourself. Scroll the manufacturers drivers that came with your version of windows and find Logitech and the type of speakers you have which you want to install.
then follow the prompts to install the speakers. You might want to go back into the sounds icon in your control panel and check the optional tabs to make sure the type of audio device you are using is also the chosen default in your pc. (i.e. headphones, desktop speakers, or surround sound system ect.)
Posted on Mar 20, 2011
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
I was deleting things in add remove hardware and now my logitech x 240 speakers dont work, also i had a yellow ? next to multimedia audio controller in device management but i downloaded something that...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 20, 2011 | Logitech X-240 Computer Speakers
I have bought a logitech x-240 speakers but there was no driver in it so i need a driver for this i need i doesnt make noise at all
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
dont forget to vote
Feb 12, 2011 | Logitech X-240 Computer Speakers
My speakers are connected to the computer and it says its not working no volume comes out. so what is the problem?
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 21, 2010 | Logitech X-240 Computer Speakers
I recently needed to reboot my computer back to factory setting due to what I figure was a virus now my speakers won't work. I have speakers labeled Logitech X-530 do I need a disk to add this as new...
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 07, 2010 | Logitech X-530 Computer Speakers
I had to reformat my harddrive and ever since then, my Logitech X-240 speakers don't work. The sound is muffled. If I plug in headphones to my PC or to the headphone port on the power button for these...
It seems odd that your speakers would die after reformatting the driver. I would recommend trying to update the drivers for the sound device. It is possible that some sort of mixer software or enhanced features of the sound card are disabled. Also ensure that they are plugged into the green port on your sound device.
Jun 15, 2010 | Logitech X-240 Computer Speakers
Reformatted Computer. No Sound.
Looks like you haven't installed your audio drivers.
Dec 27, 2009 | Logitech X-240 Computer Speakers
I recetly got a new hard drive and now for some reason my speakers wont work, I get a message that pops up saying there is a problem with your audio/video configuration
did you reload you OS on this new hard drive. If so then you need to reload you drivers for you sound card. click on your start menu and then right click on My computer and go to properties. you should see a tap that says hardware then go to your device manager to see if you have any yellow if you see yellow then you need those drivers.
Aug 25, 2009 | Logitech X-240 iPod Speaker System
I have x 240 speakers but no audio. Where can I download the sound drive for the speakers for them to work?
www.logitech.com. Click on the support link. Lookup your specific model # and select the operating system you are using. The driver file should appear for download. Gownload and install. Reboot and you should be all set. Hope this helps.
Jul 11, 2009 | Logitech X-240 Computer Speakers
Computers & Internet Logo
192 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
