Question about Proform XP Weight Loss 620 Treadmill
My Proform XP 620 WeightLoss treadmill incline doesn't work. When I try to set the incline to any number, it jumps to 10 but doesn't actually incline. Any suggestions?
    Top Expert:
  • Proform Master
  • 12,223 Answers
Incline trouble.
You most likely have a wiring harness problem. Get parts at usedtreadmillrepairparts.com
Dec 25, 2013 | Proform 7.0 Crosstrainer Treadmill
Hi, our proform 790 tr treadmill is aorund six years old and the walking belt and height motor seem to be going. Is it worth replacing these and is it fairly straightforward?
Changing a walking belt takes about an hour for someone who has done it before. Check the walking deck for scratches, damage as well. Often times if the belt is worn out, the deck needs to be replaced as well. Belts vary in price depending on the make and model of treadmill. Parts can be ordered by calling the number found on the model number sticker on the treadmill. There are 10 different machines with the 790t model name. To get the correct parts find the actual model number (will start with "H"). The parts come with replacement instructions.
Belt $105 Deck $190
As for the incline motor, it is very rare to change that part. It may just require calibration. Start the machine . Press incline up and hold, remove the safety key. Now reinsert the safety key. The machine should rise to full incline then back down to minimum. Once the cycle is complete, the treadmill should work normally. If the incline sensor is defective, the motor will have to be replaced. Incline motor $150.
Feb 26, 2011 | Proform 790T Treadmill
ProForm XP Weight Loss 620 Treadmill: i have lost the kye can it start running without i...
Generally NO, but try something like a fridge magnet, it worked for me on my HyperExtension treadmill
May 17, 2010 | Proform XP Weight Loss 620 Treadmill
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Proform treadmill CR610 won't incline
Open the cover where the main motor is there
Tight the connector for Incline motor, and clean it with special contact cleaner for electronic.
2) See if there are wires loose,
3) Measure the 110 vac for forward and backward,
4) If there are , measure the l. switch or Capacitor for faulty and replace.
5) If there nOT 110VAC in forward or backward, replace the controller board motor.
6) If there are 110VAC, replace the Incline motor.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 28, 2017 | Proform 675 Crosstrainer Treadmill
Ifit treadmill will not incline but everything else works, how do I fix the incline
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
Nov 23, 2009 | Proform Quick Burn Pro Treadmill with 12...
Incline on treadmill is acting strange
Open the motor cover. There should be a service sheet in there.
Read Option 2 & try it.
May 12, 2009 | Proform XP 542S TREADMILL Drive Motor
Treadmill has always been on a constant incline
Run the machine through calibration. If this does not work you will have either a bad controller or incline motor is bad.
Mar 29, 2009 | Proform XP Weight Loss 620 Treadmill
Treadmill will not maintain the correct speed.
You can get a book by calling 1-800-999-3756. The treadmill you are usine in a cheaper model. the motors on those units are not that strong. when you incline your unit gravity make the belt move faster. Remember incline put a lot of pressure on you lower spine. This can cause injury for some.
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Jan 29, 2009 | Proform XP Weight Loss 620 Treadmill
Unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
Pull the latch knob to the left and hold it. It may be necessary
to push the frame forward as you pull the knob to
the left. Pivot the frame downward and release the latch
knob.
2. Hold the metal frame firmly with both hands and lower
it to the floor. CAUTION: Do not grip only the plastic
foot rails or drop the frame to the floor. Bend your legs
and keep your back straight.
Jan 08, 2009 | Proform XP Weight Loss 620 Treadmill
Proform XP Weight Loss 620 Treadmill Logo
194 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
