Question about Craftsman Garden
Hi! My craftsman gas powered chainsaw will not start. I stopped it to remove some tree debris and when I went to start it again it will not start. Fuel is full, oil is in. I primed it. The chain is adjusted properly. Can't figure out why. I even let the chainsaw cool down and nothing.... What could it be?
  • 784 Answers
Check spark plug, is it ok. If its not helping, let me know.
Posted on Mar 20, 2011
Where can I get a new trigger for my craft an electric chain saw?
Are you sure it isn't a 'CRAFTSMAN' chain saw?
Google
make model spares
Craftsman Chainsaw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-chainsaw-parts-c-158286_172209.html
Fix your Craftsman Chainsaw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
Gas Chainsaw Parts ' Sears
parts.sears.ca/parts/lawn-equipment/gas-chainsaw-parts Are you looking for top quality components that could help get your chainsaw working again? You can rely on the skilled parts specialists at Sears to provide you ...
Craftsman Chainsaw Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a30b317/Craftsman-Chainsaw-Parts Looking for parts for your Craftsman Chainsaw? RepairClinic.com has the appliance parts, lawn equipment parts and heating/cooling parts you need!
Google
Jun 04, 2017 | Electric Garden
Husqvarna Model#136 Serial#20033000836 chainsaw. When I first start my chainsaw, it starts on the first or second pull and it will run perfect until it runs out of gas. I have to wait until it cools...
Your fuel octane is GREAT ! Good to hear you are using fresh fuel. Make sure to use Husqvarna HP oil. It makes a difference of the heat generated by the engine.
1) If you can: Do not run the saw dry when cutting. As soon as you have the indication that it is almost dry, stop. Remove the fuel cap to remove pressure in the tank. Allow a 5 minute cool down before refueling.
2) I see your saw is a 2003, you may have debris under the flywheel shrouding restricting air flow: remove the recoil assembly and flywheel cover/shroud under the recoil. (if it has one)
Check to see if debris has gathered around cylinder fins.
Clean with compressed air. The ability for the flywheel to breath means more air to cool the cylinder and lower the overall operating temperature of the engine.
3) Make sure the air filter is clean and area is free of debris.
* Each item may be small, but each one builds on the operating temperature.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Mar 24, 2017 | Husqvarna Garden
Starts runs but high speed or on tree runs rough like gas problem
there are two adjustment screws on the carb that you can mess with it sounds like it is out of adjustment a little bit one should say hi the other lo try the high adjustment count the number of turns so it can go back where it was
Jan 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
How to attach remington chainsaw to pole?
This thing is a little monster. I've used it to cut down several small trees and limbs from larger trees. I only need to use the gas-powered chainsaw for the large stuff. I love being able to attach and remove it from the pole. More details The Ultimate Remington Electric Chainsaw Reviews
May 21, 2010 | Remington Electric Pole Saw
Chain stops when contact is made with tree
I'm assuming that the engine continues to run, but the chain stops moving. Remove the bar and chain. If the clutch internals are full of bar oil and other debris, try washing out the clutch with spray carburetor cleaner from an auto parts store. After it dries, inspect the shoe faces and inner drum area for excessive burning or scoring. Apply a small amount of oil to the clutch hub bearing, then reassemble the bar and chain. If the chain now cuts correctly, you are home free. If it doesn't, then the clutch will need replacement. Hope this helps!
May 17, 2010 | Garden
Saw starts, but has no power.
Make sure air filter is clean.A blocked air filter will make the mixture too rich
May 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My chainsaw quite suddenly. i restarted it but
1. The kickback brake, if equipped, was triggered to stop the chain.
2. The chain is jammed with saw dust/debris (it doesn't take much)
3. the bar sprocket is damaged.
4. The chain guide teeth are damaged and not sliding through the bar guide groove smoothly
5. The chain is adjusted too tightly.
6. You are out of bar oil and friction has stopped it/damaged the bar and/or chain
7. The motor sprocket clutch is damaged.
That should cover all of the basics to look over.
Nov 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Craftman Chainsaw do not run
Extreme Flooding by Dolfoff
Please follow this link, http://www.fixya.com/support/t3226410-no_spark_new_plug_but_continues_flood cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button HTH
Lou
Oct 20, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
572 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
