Question about Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer
The safety tip came off the SB-2n1 nailer. Any way I can get a detailed diagram of the tip area to figure out how to put this thing back on.
2 Suggested Answers
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
Bostitch SB-1850BN. I bought a bundle of nail guns over a year ago, today I go to use this gun for the first time and just get a very poor poof of air coming out, no nail. I've tried it with pressure in...
At the end where you attach the air hose is the nailer imprinted with the words "add oil"? If so; add a few drops of oil designed for air nailers.
Also check to make sure no nails are stuck in the tip of the nailer and the return mechanism is reset.
Oct 20, 2017 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How do i adjust the nail depth on my bostitch n80 sb
The part of the gun that touches the work surface and acts as the safety so the gun won't fire unless pressed down on something is two peices bolted together. If you losten the nuts the bottom part will slide up and down. If you make the tip longer, the nail will be left higher (proud) in the workpeice. If you make the tip shorter the nail will be set deeper (counter sunk) into the workpeice.
Aug 26, 2012 | Stanley Air Tools & Compressors
Stanley Bostitch SB-1664FN will not activate at all when ptrigger is pulled. Air supply is OK- Plunges but will not fire :-o ??
Sounds like a safety mechanism not activating the trigger. If you have the manual look for the breakdown diagram and check that everything is in place on the gun. If not go here and you can get manual.
http://servicenet.bostitch.com/Products/Detail?productNumber=SB-1664FN
May 27, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
MODEL SB-1850BN I CAN'T FIGURE OUT HOW TO RELOAD STAPLES
the unit side loads, yellow button when pushed, will slide back, allowing you to load it.
Mar 06, 2011 | Stanley Tools & Hardware - Others
Does not shoot staple does this have lock out?
YES YOU DO HAVE TO PUSH IT TO THE WORK FOR IT TO SHOOT WENT WILL IT DO IF ANY THING
Nov 27, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Paslode gun will not engage the fan when tip depressed
if this is the framer, could be quite a few things. first do you have nails in the magazine, the safety might be bent not allowing full travel, the spark unit might be faulty. If you are comfortable with some partial disassembly, let me know and I will go into further detail for you on troubleshooting, you will need an allen wrench the size of the cap head screws. Let me know
Oct 03, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Extra fitting on my Porter Cable?
CANT FIGURE OUT WHAT YOU HAVE. IF ITS ON THE REGULATOR - THE REGULATOR USUALLY HAS AN INLET, OUTLET, GAUGE PORT AND A PLUG IN THE OTHER SIDE IN CASE YOU NEED TO MOVE THE GAUGE. SOME MANUFACTURERS PUT SAFETY VALVES IN THIS PLUG PORT. IF THIS DOESNT FIX IT GIVE A LITTLE MORE DETAIL. IS THERE ANYTHING WRITTEN ON IT. HOPE THIS HELPS, JODY
Apr 26, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter/Cable 15 gauge angle finish nailer
The driver assembly can sometimes get bent or the tip can get a little deformed causing it to hang up in the nose. Other than that, not much else it could be if you rebuilt the whole thing
Dec 31, 2008 | Porter Cable 16 - Gauge Finish Brad Nailer...
Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer Logo
47 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
