Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
Need an AC power supply for a 96300-41001-012 external hard drive What size or number should I get.
    Scholar:
  • 79 Answers
It is a 12V, 2A, tip positive supply.
Posted on Mar 21, 2011
How can I get a replacement power supply?
What you are after is an AC adapter this model I found on ebay has 120 volts to 240 volts to 12 volts make sure the DC voltage output matches the Voltage of your hard drive. The current output has to be the same amount or larger in value. So if your drive needs 2A a 2A or larger value means it can handle the current load put on it by the Hard drive.
http://www.ebay.com.au/itm/AC-DC-Adapter-For-SimpleTech-96300-40001-001-SimpleDrive-HD-Power-Supply-Cord-/400716519670?pt=US_Monitor_Power_Supplies&hash=item5d4c90d8f6
or
http://www.ebay.com.au/itm/12V-AC-Adapter-For-SimpleTech-Simpledrive-External-Hard-Drive-HD-Power-Supply-/281311386852?pt=Laptop_Adapters_Chargers&hash=item417f771ce4
this one below matches the exact model number of your hard drive
http://www.ebay.com.au/itm/AC-Adapter-For-SIMPLETECH-BOM-No-96300-41001-133-96300-41001-045-96300-41001-073-/400705526395?pt=US_MP3_Player_Chargers_Cradles&hash=item5d4be91a7b
Jun 04, 2014 | Simple Technology 96300-41001-073 1tb...
Need to know what AC adapter to use with my Firelite. Have a number of AC adapters but not sure which one goes with my unit
First ..this is an usb disk ..and usually it does not need an external power supply but in special cases when it is plugged in something it can not sustain it ..i understood it does have a power supply plug ..but ..I repeat ..it should work on the usb alone ..and get the power from it ..
If you experience some issues and need to know if ti will work when you power it external ..the values are written on the back of teh drive ..or near the plug ..You will only need to have the right jack ..and the voltage to match ..beware of any higher voltage ..it may damage it right the way ..
Dec 28, 2011 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I have a Maxtor external driver and the AC adapter is not working. I need a new AC adapter and local stores do not have it. How can you help?
There are "generic" power supplies that might meet your needs.
This is a response I gave to another user who had a different external HDD and needed a power supply.
The hard drive unit itself should be able to supply you with the required DC input voltage (hopefully there is some kind of label on the enclosure).
You could try one of these or something similar. It comes with 6 interchangeable heads and has adjustable DC voltage. This is just one of many available.
http://www.amazon.com/Hosa-ACD477-100-240V-Voltage-Adaptor/dp/B000Z31G3M
I cannot guarantee any of these supplied heads will fit your particular drive (same with the dc voltage). Some local retailers
often have these types of adapters and you might be able to determine what size you need by looking at one. Most of the
Externall HDD need 12VDC and 18+ watts of power.
Here is an online site also.
www.12Vadapters.com
I have used DC units similar to these in the past when I have lost a power supply.
Hopefully with a minimum of effort you can get a working solution.
Feb 24, 2011 | Maxtor Computers & Internet
I need new Power Supply for Western Digital External Hard Drive
That's good information to know, but what is your question?
Aug 01, 2010 | Computers & Internet
What kind of external power supply does it need if
Portable HDDs normally have a dual cable USB with the thicker cable being the power and data and the thinner one power only. Many manufacturers now make PSUs with USB sockets
Mar 06, 2010 | FireLite (USBFLB80) Hard Drive
Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Feb 22, 2010 | Western Digital Elements powered by WD 320...
Simpletech 320GB BOM No.: 96300-41001-012 is new has never worked
The original power supply is "SB2D-020-1HA SIMPLETECH AC ADAPTER 12V 1.5A FOR EXTERNAL HARD DRIVE" . Just find a replacement with the correct size plug (center positive) that supplies 12v DC at 1.5amps (1500ma)
Mar 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
417 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
