Question about RCA P61927 61" Rear Projection Television
Can i upgrade to high def on this tv model p61937
    Novelist:
  • 99 Answers
No,
You would need to purchase a new tv. TVs are either Hi-def, or they are not.
Posted on Mar 20, 2011
My Craig High Def LCD TV has lost its signal when I connect my HDMI cable. Do I need to upgrade TV Software?
Chances are real good it's a bad HDMI cable. Try swapping it out with one you know works.
Aug 22, 2015 | Craig Televison & Video
I have an Apex digital 32" LCD TV Model LD 3249 and Serial #36056009262 Is this a high definition TV
Yes. 720p High-Def capable.
Remember you have to have a High-Def signal source to actually view High-Definition video. This means local broadcast TV in HD or digital cable TV with HD service and a HD channel or satellite or a Bluray Disc.
Mar 15, 2011 | Televison & Video
Can't get HD on my TV. Tried with every cable type but cannot get High Def
2 things have to happen. first, your tv has to be set for the correct resolution, second, You need to be recieving high def from your cable/sat provider.Your tv does not make programming high def, it allows high def.
Mar 10, 2011 | Insignia 32" 720p Flat-Panel LCD HDTV
Can't receive high def channels.
What kind and model of TV?
More than likely it is not designed to receive the hi def signals and will require a converter box.
Sep 03, 2009 | Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Can i upgrade to hd on this tv
I am not finding anything on the net about being able to upgrade it but the HD in the model # stands for high def but the tv is old enough that it may not go up as high as 1080 most likely just 480i or p which can be achieved with an s-video or might be 720 with the R/B/G connector or a DVI connector, you can look for converting cables on ebay
Jan 26, 2008 | Akai PT4298HD Rear Projection Television
Aiptek - Video and sound is out of sync
Are you recording in High Def? When I tried that on mine the same thing happened. That definitely has to be played back on Hi Def TV and the computer probably isn't capable of handling that. Switch to DVD mode, or Web cam mode and you won't have a problem.
Dec 03, 2007 | Aiptek A-HD 720P Flash Media Camcorder
Mitsubishi WS-55807 tv and my x-box 360, no high def
its under the settings on the xbox system, in the dashboard.
Aug 08, 2007 | Mitsubishi WS-55807 TV
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
