Question about Kenmore Ovens
Oven is model 665.95781. I used the cleaning cycle.Oven door will not open. Message is E1 F5. Please help!
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
Based on your description, the E1 F5 error code likely indicates that the door latch is not operating.
Make sure that the oven door is closed when you start the Self Clean cycle. Check the door switch to see if it is apparently operating properly. Open the oven door and the oven light should turn on. Press in the door switch plunger and the light should turn off. If the light switch is not operating properly, it could cause this type of problem.
If the light switch is operating properly, then you could have a failed door latch assembly. A wiring failure or a problem with the control board could also cause this failure. I recommend that you unplug the range and access the door latch assembly at the back of the range. Pull the upper and lower back panels off of the range. Caution: The edges on these panels can be sharp. Protective gloves are recommended. With the panels off, check the wire harness connections on the door latch assembly.
Posted on Mar 20, 2011
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: F5 E1 error. Oven door won't open after running
1.
If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door
    switch to control. If no damage to wires and all connectors okay, proceed to
    step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from
    memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure
    operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch
    step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals).
Replace switch if defective.
4. Measure latch switch (unlatch = switch open,
CAUTION - oven light contacts are closed). Replace switch if defective.
5. If
corrections are made in any step, reconnect power to control. Press and hold any
key for 1 minute to clear R failure code from memory. F2 will appear. Press
CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure
remains, disconnect power and replace control.
Note:
Applies to all F5-E... codes.
F5 - E1
Posted on Feb 23, 2011
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven won't heat flashes F2EO and 5D on
List below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appears, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad. Replace Keypad.
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Below applies only to the two digit display models for the brands above.
F0 Defective ERC Replace ERC
F1 Defective ERC Replace ERC
F2 Oven over heat Replace defective Sensor
F3 Oven Sensor Open Check/Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground.
F7 Shorted or sticking button Clean button or replace ERC
F8 Defective ERC Replace ERC
F9 Door Latch Error Check latch and latch circuit
Mar 20, 2016 | Ovens
I was using the Self Clean on the oven after a couple of hours I got an error message E1 and F5 - and the oven door is locked. I have no idea what that means or how to get the door open again. I tried...
Hello there and thank you for choosing fixya
Ok before i get into the error codes just a few words here about the self cleaning feature
This the feature that is the most harsh on these ovens due to the extremly high temperatures that is produced then this can and will cause serious problems if not done correctly
I know that people like this feature but i highly suggest that if you are going to use it please try to get the oven as clean as possiable before using this feature this helps the cleaning cycle tremendously ok?
Now for the error code
the e1 error dode is due to the door being locked so to repair this you need to unplug the oven and leave it sit for at least 1 hour this allows for the internal reset feature to reset the oven controle
after the hour is over plug it back in and in 1 to 5 min you may hear a audiable beep or click if so simply press the cancel button and attempt to open the door if so great you should be ok
Now for the bad one
The F5 code is due to the oven control sensing the extreem heat during self cleaning
and sensing that the controls are not controlling the temperature during cleaning which is a bad thing this can and will cause the control board to fail and once again due to the excessive heat
So hopefully once the oven has been unplugged for the hour and reset you should be allright but if not than you do have a bigger problem meaning that your controle board is shot ok?
Please keep me posted on how this is going so i can send you more information on this
Best regards Mike
Feb 18, 2011 | Whirlpool Ovens
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
E1 F5 Error on Whirlpool Accubake Oven
The lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed srew driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Apr 07, 2009 | Ovens
E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 07, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
E1 f5 error code whirlpool gr399lxhs
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^$%^
Mar 25, 2008 | Whirlpool GBS307PR Electric Single Oven
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
89 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
